0.89 - MAX Start Index is 99 in Batch Convert
Moderators: XnTriq, xnview, Dreamer
Optic
Post by Optic » Thu Jan 25, 2018 5:38 am
Hi there,
I think this is an oversight.
Inside batch convert, it is great you can put a number sequence using #
But later I need to change "Start index" to continue the number sequence on a later batch convert.
The start index maximum number is 99
I need to continue sequence with a higher starting number than that! e.g. I can't change it to 200.
Please consider allowing us to put larger numbers (or even unlimited)
Thank you.
Re: 0.89 - MAX Start Index is 99 in Batch Convert
Post by xnview » Fri Jan 26, 2018 6:31 am
ok, will be changed
Post by xnview » Mon Feb 12, 2018 10:12 am
This problem is supposed to be fixed in XnView MP 0.90. Please check and confirm the bug fix here.
Optic
Post by Optic » Mon May 20, 2019 12:16 am
Hi Pierre, confirming this is resolved.
Thanks and sorry for late reply.
