XnView MP 0.89
Locked
XnView MP 0.89
Post by xnview » Tue Jan 16, 2018 7:02 pm
Please, don't post bugs or request in this topic!
You can download XnView MP 0.89 here:
Windows x32 ZIP version: http://download.xnview.com/XnViewMP-win.zip
Windows x32 SETUP version: http://download.xnview.com/XnViewMP-win.exe
  • SHA256: 7C1B1BCC4AFBEE9802C54B334DC03C0AE554EF7281030231A3178E8057DE640D
Windows x64 ZIP version: http://download.xnview.com/XnViewMP-win-x64.zip
Windows x64 SETUP version: http://download.xnview.com/XnViewMP-win-x64.exe
  • SHA256: 79F852C616AABE3E4E21AD1F9998A1FE8339AA41C710514D97E21C4AAA67757F
Mac x64 TGZ version: http://download.xnview.com/XnViewMP-mac.tgz
Mac x64 DMG version: http://download.xnview.com/XnViewMP-mac.dmg
Linux TGZ version: http://download.xnview.com/XnViewMP-linux.tgz
Linux DEB version: http://download.xnview.com/XnViewMP-linux.deb
Linux x64 TGZ version: http://download.xnview.com/XnViewMP-linux-x64.tgz
Linux x64 DEB version: http://download.xnview.com/XnViewMP-linux-x64.deb
Linux x64 AppImages version: http://download.xnview.com/XnView_MP-0. ... 4.AppImage
Changelog 0.89:
1352: [New] Curves adjustment
1351: [New] Split - viewtopic.php?f=82&t=36813
0689: [New] Slideshow
1349: [New] Levels in Batch Convert
1346: [New] IPTC/XMP can be edited on RAW files
1345: [New] Windows default context menu by pressing CTRL key (thumbnails view)
1344: [New] Recursive mode and Synchronize Browser - viewtopic.php?f=60&t=35236
1332: [New] MegaPixels placeholder - viewtopic.php?f=60&t=35619
1354: [Bug] Empty folders left after move operations - viewtopic.php?f=62&t=36862
1353: [Bug] XMP sidecar not used loaded
1350: [Bug] Create/File listing: wrong output if field contains carriage return - viewtopic.php?f=62&t=36789
1348: [Bug] Current file not good after select tagged files - viewtopic.php?f=82&t=36735
1347: [Bug] MacOSX: saving doesn't use correct format
1343: [Bug] Category Sets not disabled when no selection
1342: [Bug] Bold text must be used in History/Suggested sets panel - viewtopic.php?f=62&t=36666
1341: [Bug] Rating and categories together not working - viewtopic.php?f=62&t=36678
1340: [Bug] Linux: Watermark problem - viewtopic.php?f=82&t=36684
1339: [Bug] Save selection between view tab - viewtopic.php?f=82&t=36669
1338: [Bug] No more thumbnails after rename folder - viewtopic.php?f=62&t=36571
1337: [New] Registration name/code in registry [HKEY_LOCAL_MACHINE\SOFTWARE\XnView\XnViewMP]
1336: [Bug] Can't use 'A', 'D' in view mode as shortcut - viewtopic.php?f=62&t=36606
1335: [Bug] Linux: Menu disappears - viewtopic.php?f=62&t=36623
1334: [Bug] Renaming subfolder is not changed in catalog - viewtopic.php?f=110&t=36410
1333: [Bug] Linux: Overwrite without warning - viewtopic.php?f=111&t=35910
1331: [Bug] MacOSX: Crash when switching from fullscreen view - viewtopic.php?f=62&t=36597
1330: [Bug] PDF/PS read problem on MacOSX
1328: [Bug] 'All' category returns empty list - viewtopic.php?f=83&t=36386
1327: [Bug] No info in statusbar for first file - viewtopic.php?f=62&t=36579
Changelog 0.88:
1326: [New] More used formats at the top in save dialog
1325: [New] Policy entries in xnview.ini
1312: [New] Exposure adjsutement in edit mode - http://newsgroup.xnview.com/viewtopic.php?t=36368
1304: [New] FLIF 0.3
1324: [Bug] Paint problem on scaled display - http://newsgroup.xnview.com/viewtopic.php?t=36458
1323: [Bug] 'Open With' & path with %1 - http://newsgroup.xnview.com/viewtopic.php?t=36538
1322: [Bug] Category 'Special items' doesn't use 'Match' setting - http://newsgroup.xnview.com/viewtopic.php?t=36386
1321: [Bug] Crash when using Mode dialog - http://newsgroup.xnview.com/viewtopic.php?t=36330
1320: [Bug] Catalog not correctly updated after folder renaming - http://newsgroup.xnview.com/viewtopic.php?t=36410
1319: [Bug] Batch convert: 'as original' format not restored
1318: [Bug] Batch convert doesn't keep creation date - http://newsgroup.xnview.com/viewtopic.php?t=36277
1317: [Bug] Linux: Database/default path problem - http://newsgroup.xnview.com/viewtopic.php?t=35447
1316: [Bug] CADIMAGE.DLL can't be used
1315: [Bug] Linux: Texts are gone - http://newsgroup.xnview.com/viewtopic.php?t=36326
1314: [Bug] Slow viewing of RAW files - http://newsgroup.xnview.com/viewtopic.php?t=36379
1311: [Bug] XnConvert should save/restore inactive actions - http://newsgroup.xnview.com/viewtopic.php?t=36252
1310: [Bug] Move To resets file date - http://newsgroup.xnview.com/viewtopic.php?t=35717
1309: [Bug] Slow batch rename with RAW files - http://newsgroup.xnview.com/viewtopic.php?t=36316
1308: [Bug] Collage problem - http://newsgroup.xnview.com/viewtopic.php?t=35979
1307: [Bug] Auto image size not kept - http://newsgroup.xnview.com/viewtopic.php?t=36276
1306: [Bug] {Filename] in 'File Listing' use pathname - http://newsgroup.xnview.com/viewtopic.php?t=36302
1305: [Bug] Empty categories after rename folder (base path) - http://newsgroup.xnview.com/viewtopic.php?t=36186
1303: [Bug] Transparent SVG - http://newsgroup.xnview.com/viewtopic.php?t=30579
1302: [Bug] Save selection & dot in filename - http://newsgroup.xnview.com/viewtopic.php?t=35910
1301: [Bug] 'Copy' in edit mode doesn't copy filename
Changelog 0.87:
1296: [New] Imgur service
1165: [New] Guetzli JPEG from Google - http://newsgroup.xnview.com/viewtopic.php?t=35158
1291: [New] Import&sort: new subfolder template
1287: [New] Zealous Crop - http://newsgroup.xnview.com/viewtopic.php?t=35860
1286: [New] Film simulation (clut from InstaCam)
1279: [New] Batch Convert - Start index for #
1275: [New] Setting for highlight selection - http://newsgroup.xnview.com/viewtopic.php?t=35808
1249: [New] Comment field (embbeded or description) - http://newsgroup.xnview.com/viewtopic.php?t=35281
0845: [New] Delete files or categories in browser - http://newsgroup.xnview.com/viewtopic.php?t=32816
1235: [New] Comment encoding - http://newsgroup.xnview.com/viewtopic.php?t=35542
1299: [Bug] Contact sheet unwanted spacing - http://newsgroup.xnview.com/viewtopic.php?t=36192
1298: [Bug] Batch rename and GPS special chars - http://newsgroup.xnview.com/viewtopic.php?t=36145
1297: [Bug] Thumbnail orientation after 'Edit IPTC' - http://newsgroup.xnview.com/viewtopic.php?t=36114
1295: [Bug] Resize dialog - Maximum size value in mm - http://newsgroup.xnview.com/viewtopic.php?f=79&t=35975
1295: [Bug] Resize dialog - Maximum size value in mm - http://newsgroup.xnview.com/viewtopic.php?t=35975
1294: [Bug] TIFF with 4 BitsPerSample - http://newsgroup.xnview.com/viewtopic.php?t=35961
1293: [Bug] Message when ghostscript is not found
1292: [Bug] Random msg: "This picture will be converted..." - http://newsgroup.xnview.com/viewtopic.php?t=35223
1290: [Bug] Rename on Folder tree bad focus - http://newsgroup.xnview.com/viewtopic.php?t=35922
1289: [Bug] Drag&Drop file in thumbnail view (empty space) should make a copy
1288: [Bug] Copy-Paste Auto-naming Discrepancy - http://newsgroup.xnview.com/viewtopic.php?t=35882
1285: [Bug] Annotation in contact sheet
1284: [Bug] Batch convert: Save and delete original - http://newsgroup.xnview.com/viewtopic.php?t=35670
1283: [Bug] 'Fixed ratio' should be set with image ratio - http://newsgroup.xnview.com/viewtopic.php?t=35848
1282: [Bug] Sort in view mode not always correct - http://newsgroup.xnview.com/viewtopic.php?t=35832
1281: [Bug] Favorites pane sometimes empty - http://newsgroup.xnview.com/viewtopic.php?t=35834
1280: [Bug] PSD thumbnail support - http://newsgroup.xnview.com/viewtopic.php?t=35810
1278: [Bug] Crash after file(s) are deleted or moved - http://newsgroup.xnview.com/viewtopic.php?t=35462
1277: [Bug] Batch Convert: Save 'Delete' question choice
1276: [Bug] "Update catalog from files" remove categories - http://newsgroup.xnview.com/viewtopic.php?t=35698
1274: [Bug] Copy instead of move in the same share - http://newsgroup.xnview.com/viewtopic.php?t=35504
1273: [Bug] Import category list - http://newsgroup.xnview.com/viewtopic.php?t=35741
1272: [Bug] Custom order doesn't reset header indicator - http://newsgroup.xnview.com/viewtopic.php?t=35296
1271: [Bug] Sidecar: Export Rating/label doesn't export categories - Export categories doesn't export rating/label
1270: [Bug] Update catalog needs 'Import subject' setting - http://newsgroup.xnview.com/viewtopic.php?t=35698
1269: [Bug] Renaming video file in use - http://newsgroup.xnview.com/viewtopic.php?t=35254
1268: [Bug] XnView MP can rename files to too long names - http://newsgroup.xnview.com/viewtopic.php?t=34411
1267: [Bug] Tabbing impossible in dialogs with multi-line fields - http://newsgroup.xnview.com/viewtopic.php?t=35244
1266: [Bug] Compare - shortcut & selection - http://newsgroup.xnview.com/viewtopic.php?t=35592
1265: [Bug] Create "joining images" based on DNG ignoring the embedded preview - http://newsgroup.xnview.com/viewtopic.php?t=35645
1232: [Bug] Fullscreen: "Quit" closes program - http://newsgroup.xnview.com/viewtopic.php?t=30824
1263: [Bug] Batch convert - Canvas resize interface - http://newsgroup.xnview.com/viewtopic.php?t=35793
1264: [Bug] GPS tag missing - http://newsgroup.xnview.com/viewtopic.php?t=35690
1262: [Bug] "Maximum of view tabs" option is ignored sometimes - http://newsgroup.xnview.com/viewtopic.php?t=35247
1261: [Bug] "View » Reset X/Y" does not work - http://newsgroup.xnview.com/viewtopic.php?t=35552
1260: [Bug] Category assignment - http://newsgroup.xnview.com/viewtopic.php?t=35584
1259: [Bug] Crash when pressing <Ctrl> + </> in Browser-Mode with folder selected - http://newsgroup.xnview.com/viewtopic.php?t=35628
1258: [Bug] Moving a folder on itself in Detail View - http://newsgroup.xnview.com/viewtopic.php?t=35370
1257: [Bug] Theme not checked - http://newsgroup.xnview.com/viewtopic.php?t=18636
1256: [Bug] Preview and Browser navigation issues with videos - http://newsgroup.xnview.com/viewtopic.php?t=35222
1255: [Bug] Mac folder numeric sorting - http://newsgroup.xnview.com/viewtopic.php?t=34548
1254: [Bug] Selection ratio in main menu and crop toolbar out of sync - http://newsgroup.xnview.com/viewtopic.php?t=35526
1253: [Bug] Slide show: Same image shown multiple times - http://newsgroup.xnview.com/viewtopic.php?t=35062
1252: [Bug] Drag and drop doesn't work in List view - http://newsgroup.xnview.com/viewtopic.php?t=35297
1251: [Bug] PSB format - http://newsgroup.xnview.com/viewtopic.php?t=34134
1250: [Bug] Restoring layout reverts info pane tab - http://newsgroup.xnview.com/viewtopic.php?t=35088
1248: [Bug] Manual refresh doesn't refresh folder tree - http://newsgroup.xnview.com/viewtopic.php?t=35075
1247: [Bug] Toolbar item "show files in subfolder" doesn't show stat - http://newsgroup.xnview.com/viewtopic.php?t=29652
1246: [Bug] Browser: Menu "Edit > Properties" missing - http://newsgroup.xnview.com/viewtopic.php?t=33970
1079: [Bug] Wrong multi-selection after mouse wheel selection - http://newsgroup.xnview.com/viewtopic.php?t=34719
1245: [Bug] Bug when selecting files with the keyboard - http://newsgroup.xnview.com/viewtopic.php?t=33945
1244: [Bug] UI: Slash in path - http://newsgroup.xnview.com/viewtopic.php?t=34392
1243: [Bug] Resizing problem - http://newsgroup.xnview.com/viewtopic.php?t=31350
1242: [Bug] Copy Image does not work - http://newsgroup.xnview.com/viewtopic.php?t=34652
1241: [Bug] Thumbs+Details: Strange behaviour when Renaming - http://newsgroup.xnview.com/viewtopic.php?t=35225
1240: [Bug] Reset fit when next/previous file - http://newsgroup.xnview.com/viewtopic.php?t=34416
1239: [Bug] Results of scanning aren't added to the browser - http://newsgroup.xnview.com/viewtopic.php?t=34446
1238: [Bug] Add Noise filter does not respect the mask - http://newsgroup.xnview.com/viewtopic.php?t=35061
1237: [Bug] Artefacts when high quality zooming 4-color greyscale - http://newsgroup.xnview.com/viewtopic.php?t=35064
1236: [Bug] Large image thumbnail problem - Thumbnail of large images are dark
1234: [Bug] Hierarchy not saved in IPTC keywords - http://newsgroup.xnview.com/viewtopic.php?t=35755
1233: [Bug] Darkened screen when closing context menu - http://newsgroup.xnview.com/viewtopic.php?t=35104
1231: [Bug] Keyboard shortcuts "fast image scrolling" missing - http://newsgroup.xnview.com/viewtopic.php?t=33224
1230: [Bug] Details View: Middle Mouse Click Doesn't Open File - http://newsgroup.xnview.com/viewtopic.php?t=33618
1229: [Bug] When the Favourite is non-existent - http://newsgroup.xnview.com/viewtopic.php?t=30769
1228: [Bug] Database search progress not indicated - http://newsgroup.xnview.com/viewtopic.php?t=35095
1227: [Bug] "Shadow" & "Conbright" don't respect selection - http://newsgroup.xnview.com/viewtopic.php?t=35193
1226: [Bug] Video volume is changed when changing mode - http://newsgroup.xnview.com/viewtopic.php?t=35331
1225: [Bug] Status bar not updated with 1st file at beginning - http://newsgroup.xnview.com/viewtopic.php?t=35175
1224: [Bug] Purge 'Most recently used files&dirs' on exit - http://newsgroup.xnview.com/viewtopic.php?t=16966
1223: [Bug] Focus lost after searching - http://newsgroup.xnview.com/viewtopic.php?t=35177
1222: [Bug] Symbolic directory link - http://newsgroup.xnview.com/viewtopic.php?t=34417
1221: [Bug] Volume doesn't always mute when at zero - http://newsgroup.xnview.com/viewtopic.php?t=34888
1220: [Bug] Tree navigation with keyboard issue - http://newsgroup.xnview.com/viewtopic.php?t=35329
1219: [Bug] Image "jumps" when selecting requires scrolling - http://newsgroup.xnview.com/viewtopic.php?t=34969
1218: [Bug] Autoexpand subfolders in folder tree - http://newsgroup.xnview.com/viewtopic.php?t=35293
1217: [Bug] Disable catalog - http://newsgroup.xnview.com/viewtopic.php?t=35521
1216: [Bug] Thumbnail for folder's link - http://newsgroup.xnview.com/viewtopic.php?t=33943
1215: [Bug] .jpg_original files after editing metadata - http://newsgroup.xnview.com/viewtopic.php?t=35404
1214: [Bug] Multi-selection in browser: Wrong state of menu items - http://newsgroup.xnview.com/viewtopic.php?t=35346
1213: [Bug] Wrong thumbnail orientation for raw files - http://newsgroup.xnview.com/viewtopic.php?t=35511
1212: [Bug] Batch renaming, enter key problem - http://newsgroup.xnview.com/viewtopic.php?t=35260
1211: [Bug] HLS-Temperature don't use selection rectangle - http://newsgroup.xnview.com/viewtopic.php?t=35251
1210: [Bug] No Drag&Drop to parent folder - http://newsgroup.xnview.com/viewtopic.php?t=34871
1209: [Bug] Manually set video position ignored - http://newsgroup.xnview.com/viewtopic.php?t=35292
1208: [Bug] Thumbnails+filenames view: Filename truncated - http://newsgroup.xnview.com/viewtopic.php?t=35258
1207: [Bug] View mode doesn't detect file removed - http://newsgroup.xnview.com/viewtopic.php?t=35435
1206: [Bug] Keep Ratio and Preset Sizes Issues - http://newsgroup.xnview.com/viewtopic.php?t=35548
1205: [Bug] No message box "...will lose all existing metadata" - http://newsgroup.xnview.com/viewtopic.php?t=35429
1204: [Bug] Change EXIF orientation field when EXIF doesn't exist - http://newsgroup.xnview.com/viewtopic.php?t=35749
1203: [Bug] Remove file on Linux sometimes doesn't work - http://newsgroup.xnview.com/viewtopic.p ... 8&p=142932
1202: [Bug] Batch convert watermark: when watermark is bigger than image + right position
1199: [Bug] Can't disable 'format color' on Thumbnails+label mode
1200: [Bug] Edit GPS change always the file date - http://newsgroup.xnview.com/viewtopic.php?t=35682
1198: [Bug] Settings in Registry - http://newsgroup.xnview.com/viewtopic.php?t=35603
1196: [Bug] TIF > 2GB & multipage - http://newsgroup.xnview.com/viewtopic.php?t=35056
Moderator & Librarian
Re: XnView MP 0.89
Post by XnTriq » Tue Jan 16, 2018 9:15 pm
xnview wrote:1352: [New] Curves adjustment
Great release, Pierre :-D
oops66
Re: XnView MP 0.89
Post by oops66 » Sat Feb 17, 2018 6:05 pm
Hello all,
Thank you Pierre for the AppImages it useful and it's a good idea.
Linux x64 version: http://download.xnview.com/XnView_MP-0. ... 4.AppImage
XnViewMP 0.82 Linux X64 - Ubuntu 16.04 LTS - X64
Locked
