**** Please do not post bugs or requests in this topic!
**** In this new test version 0.89 beta 2 various bugs have been fixed. All reported bugs that aren't listed in the changelog below will be fixed in a later release. Please do not re-report a bug which wasn't fixed yet.
XnView 0.89 beta 2 is available for beta testing. You can download XnView MP 0.89 beta 2 here:
Windows x64 ZIP version: http://www.xnview.com/beta/XnViewMP-win-x64-beta2.zip
MAcOSX TGZ version: http://www.xnview.com/beta/XnViewMP-mac-x64-beta2.tgz
If you have reported one or several bugs listed below, we'd kindly ask you to check with the latest version whether the bug really has been fixed and confirm this with a short note in the specific topic with the bug report.
Thank you for your help!
Changelog 0.89:
1352: [New] Curves adjustment
1351: [New] Split - viewtopic.php?f=82&t=36813
0689: [New] Slideshow
1349: [New] Levels in Batch Convert
1346: [New] IPTC/XMP can be edited on RAW files
1345: [New] Windows default context menu by pressing CTRL key (thumbnails view)
1344: [New] Recursive mode and Synchronize Browser - viewtopic.php?f=60&t=35236
1332: [New] MegaPixels placeholder - viewtopic.php?f=60&t=35619
1354: [Bug] Empty folders left after move operations - viewtopic.php?f=62&t=36862
1353: [Bug] XMP sidecar not used loaded
1350: [Bug] Create/File listing: wrong output if field contains carriage return - viewtopic.php?f=62&t=36789
1348: [Bug] Current file not good after select tagged files - viewtopic.php?f=82&t=36735
1347: [Bug] MacOSX: saving doesn't use correct format
1343: [Bug] Category Sets not disabled when no selection
1342: [Bug] Bold text must be used in History/Suggested sets panel - viewtopic.php?f=62&t=36666
1341: [Bug] Rating and categories together not working - viewtopic.php?f=62&t=36678
1340: [Bug] Linux: Watermark problem - viewtopic.php?f=82&t=36684
1339: [Bug] Save selection between view tab - viewtopic.php?f=82&t=36669
1338: [Bug] No more thumbnails after rename folder - viewtopic.php?f=62&t=36571
1337: [New] Registration name/code in registry [HKEY_LOCAL_MACHINE\SOFTWARE\XnView\XnViewMP]
1336: [Bug] Can't use 'A', 'D' in view mode as shortcut - viewtopic.php?f=62&t=36606
1335: [Bug] Linux: Menu disappears - viewtopic.php?f=62&t=36623
1334: [Bug] Renaming subfolder is not changed in catalog - viewtopic.php?f=110&t=36410
1333: [Bug] Linux: Overwrite without warning - viewtopic.php?f=111&t=35910
1331: [Bug] MacOSX: Crash when switching from fullscreen view - viewtopic.php?f=62&t=36597
1330: [Bug] PDF/PS read problem on MacOSX
1328: [Bug] 'All' category returns empty list - viewtopic.php?f=83&t=36386
1327: [Bug] No info in statusbar for first file - viewtopic.php?f=62&t=36579
