[0.89b1] Assigning rating deselects previously assigned categories
Moderator: Dreamer
jadO
Post by jadO » Fri Dec 29, 2017 2:45 pm
1. Open explorer view
2. Select a video thumbnail
3. From left category set panel select categories to assign
4. Now assign a rating by STRG+[Number]
5. Watch how assigned categories gets emptied.
This is another event trigger issue. Probably due to the fact that rating gets applied immediately while categories only get applied when exiting the selected file (which is not a good choice imho).
Re: [0.89b1] Assigning rating deselects previously assigned categories
Post by xnview » Wed Jan 17, 2018 8:55 am
jadO wrote: 3. From left category set panel select categories to assign
you means the bottom categories pane?
jadO
Post by jadO » Mon Jan 29, 2018 8:52 am
I mean the pane where the category sets are located (Assigned, Suggested, History etc.)
jadO
Post by jadO » Mon Jul 16, 2018 5:30 am
It just happend again with 0.91b3. Can you reprocude?
1. Select a file
2. Open category sets pane
3. Select multiple categories from sets
4. Select a rating
Actual Outcome:
1. File gets selected
2. Category sets pane gets opened
3. Categories get assigned to file
4. Rating gets applied to file immediately, clearing out the previously selected categories
The main issue here is, that categories chosen from a set do not really get assigned immediately but only after moving to another file in browser.
Post by xnview » Wed Jul 18, 2018 12:21 pm
ok i can reproduce this one
