Mysterious change in picture files - Jpeg expert opinion needed
All non-XnView related: softwares, formats, imaging, photography...
FeriM
Post by FeriM »
Hi all,
(short info)
Can someone tell me what caused the difference in the following two files ? It is the same picture, downloaded (copy/paste) from the same phone to the same win7 x64 machine at different times.
http://picpaste.com/DSC_0017-NkSWLXHf.JPG
http://picpaste.com/DSC_0017__2_-3viRfLKc.JPG
(details)
Usually I copy all the pictures from phone to a new folder, sometimes I delete them from phone, sometimes not. I discovered by chance that the same files that I copied at different times are different, it looks like some metadata change. I uploaded only a pair, but all files are affected the same way. I would like to know if the change was made by the phone itself (moving pictures to card storage?! software update?!), or some editor/viewer without user permission... however strange this might seem.
Phone is Sony Xperia Z2 (more details in file metadata), and the viewers I usually use for browsing are IrfanView, XnView and some old ACDSee...
So anyone who has an idea or can suggest a better place to ask the question, please help
Thanks
Re: Mysterious change in picture files - Jpeg expert opinion needed
EXIF makernotes is the difference
Post by michel038 »
Edit metadata with Fastphototagger :
Composite       Aperture             2.0                      2.0
Composite       FocalLength35efl     4.9 mm                   4.9 mm
Composite       ImageSize            3840x2160                3840x2160
Composite       LightValue           8.0                      8.0
Composite       Megapixels           8.3                      8.3
Composite       ShutterSpeed         1/50                     1/50
Composite       SubSecCreateDate     2017:06:12 08:57:22.206632017:06:12 08:57:22.20663
Composite       SubSecDateTimeOrigina2017:06:12 08:57:22.206632017:06:12 08:57:22.20663
Composite       SubSecModifyDate     2017:06:12 08:57:22.206632017:06:12 08:57:22.20663
Composite       ThumbnailImage       (Binary data 3561 bytes, (Binary data 3561 bytes,
EXIF:ExifIFD    ColorSpace           sRGB                     sRGB
EXIF:ExifIFD    ComponentsConfiguratiY, Cb, Cr, -             Y, Cb, Cr, -
EXIF:ExifIFD    CreateDate           2017:06:12 08:57:22      2017:06:12 08:57:22
EXIF:ExifIFD    CustomRendered       Normal                   Normal
EXIF:ExifIFD    DateTimeOriginal     2017:06:12 08:57:22      2017:06:12 08:57:22
EXIF:ExifIFD    DigitalZoomRatio     1                        1
EXIF:ExifIFD    ExifImageHeight      2160                     2160
EXIF:ExifIFD    ExifImageWidth       3840                     3840
EXIF:ExifIFD    ExifVersion          220                      220
EXIF:ExifIFD    ExposureCompensation 0                        0
EXIF:ExifIFD    ExposureMode         Auto                     Auto
EXIF:ExifIFD    ExposureTime         1/50                     1/50
EXIF:ExifIFD    Flash                Off, Did not fire        Off, Did not fire
EXIF:ExifIFD    FlashpixVersion      100                      100
EXIF:ExifIFD    FNumber              2.0                      2.0
EXIF:ExifIFD    FocalLength          4.9 mm                   4.9 mm
EXIF:ExifIFD    ISO                  80                       80
EXIF:ExifIFD    LightSource          Unknown                  Unknown
EXIF:ExifIFD    MeteringMode         Multi-segment            Multi-segment
EXIF:ExifIFD    SceneCaptureType     Standard                 Standard
EXIF:ExifIFD    ShutterSpeedValue    1/50                     1/50
EXIF:ExifIFD    SubjectDistanceRange Unknown                  Unknown
EXIF:ExifIFD    SubSecTime           206635
EXIF:ExifIFD    SubSecTimeDigitized  206635
EXIF:ExifIFD    SubSecTimeOriginal   206635
EXIF:ExifIFD    WhiteBalance         Auto                     Auto
EXIF:IFD0       Make                 Sony                     Sony
EXIF:IFD0       Model                D6503                    D6503
EXIF:IFD0       ModifyDate           2017:06:12 08:57:22      2017:06:12 08:57:22
EXIF:IFD0       Orientation          Rotate 90 CW             Rotate 90 CW
EXIF:IFD0       ResolutionUnit       inches                   inches
EXIF:IFD0       Software             23.5.A.1.291_6_f100000f  23.5.A.1.291_6_f100000f
EXIF:IFD0       SubSecTime                                    206635
EXIF:IFD0       SubSecTimeDigitized                           206635
EXIF:IFD0       SubSecTimeOriginal                            206635
EXIF:IFD0       XResolution          72                       72
EXIF:IFD0       YCbCrPositioning     Centered                 Centered
EXIF:IFD0       YResolution          72                       72
EXIF:IFD1       Compression          JPEG (old-style)         JPEG (old-style)
EXIF:IFD1       Orientation          Rotate 90 CW             Rotate 90 CW
EXIF:IFD1       ResolutionUnit       inches                   inches
EXIF:IFD1       ThumbnailLength      3561                     3561
EXIF:IFD1       ThumbnailOffset      11766                    796
EXIF:IFD1       XResolution          72                       72
EXIF:IFD1       YResolution          72                       72
EXIF:InteropIFD InteropIndex         R98 - DCF basic file (sRGR98 - DCF basic file (sRG
EXIF:InteropIFD InteropVersion       100                      100
ExifTool        ExifToolVersion      10.33                    10.33
File:System     Directory            D :\test                 D :\test
File:System     FileAccessDate       2017:11:27 23:03:59+01:002017:11:27 23:04:23+01:00
File:System     FileCreateDate       2017:11:27 23:03:59+01:002017:11:27 23:04:23+01:00
File:System     FileModifyDate       2017:11:27 23:03:59+01:002017:11:27 23:04:23+01:00
File:System     FileName             DSC_0017-c.JPG           DSC_0017-d.JPG
File:System     FilePermissions      rw-rw-rw-                rw-rw-rw-
File:System     FileSize             2.7 MB                   2.7 MB
File            BitsPerSample        8                        8
File            ColorComponents      3                        3
File            EncodingProcess      Baseline DCT, Huffman codBaseline DCT, Huffman cod
File            ExifByteOrder        Little-endian (Intel, II)Little-endian (Intel, II)
File            FileType             JPEG                     JPEG
File            FileTypeExtension    jpg                      jpg
File            ImageHeight          2160                     2160
File            ImageWidth           3840                     3840
File            MIMEType             image/jpeg               image/jpeg
File            YCbCrSubSampling     YCbCr4:2:0 (2 2)         YCbCr4:2:0 (2 2)
MakerNotes:Sony FaceInfoLength       26
MakerNotes:Sony FaceInfoOffset       94
MakerNotes:Sony FacesDetected        0
MakerNotes:Sony MetaVersion
MakerNotes:Sony SoftSkinEffect       Off
MakerNotes:Sony SonyDateTime         2017:06:12 08:57:22
MakerNotes:Sony SonyImageHeight      2160
MakerNotes:Sony SonyImageWidth       3840
FeriM
Post by FeriM »
Any idea why the maker notes are included vs missing from same files, downloaded at different points in time? Is there some setting on the phone?
Post by michel038 »
Perhaps your phone tried to detect faces later, and wrote the last 8 lines of exif metadata... and some other metadata were updated.. ?
Each software, each camera writes a lot of metadata using his own way ...
You can see some Sony metadata here : https://sno.phy.queensu.ca/~phil/exifto ... /Sony.html
Moderator & Librarian
According to Stuffware Photo Studio, there's also an empty EXIF GPS IFD in DSC_0017-NkSWLXHf.JPG which is missing in DSC_0017__2_-3viRfLKc.JPG.
