0.87 Rating and categories together not working
Moderators: XnTriq, xnview, Dreamer
jadO
Post by jadO » Wed Nov 22, 2017 8:12 pm
In the categories pane if you select a category plus a rating for filtering, no files are shown.
It is working with rating plus color label.
Re: 0.87 Rating and categories together not working
Post by michel038 » Wed Nov 22, 2017 9:22 pm
If I select...
- two or more categories, "Match,any" or "Match, all" will be applied, according to the choice selected in Match menu.
- a category and a rating, "AND" is always applied , (even if "match,any" is selected). It's a logical method.
- a category and a color "AND" is always applied . Logical also
- a rating and a color "AND" is always applied . ( "OR" could be another choice, but is there anyone who will use it ?)
- two or more ratings, "OR" is always applied . Logical . ( If a category is added, we get : cat and (rating1 or rating2) )
- two or more colors, "OR" is always applied . Logical .
no problem for me, except that the "match" menu doesn't explain.
- "Match" selection is applied only on categories . (cat1 AND/OR cat2) according to the choice "all" / "any"
- OR is always applied in ratings ( rating1 OR rating2) . Same for colors (color1 OR color2)
- if categories and ratings are selected, AND is alaways used between groups (cat1 AND/OR cat2) AND (rating1 OR rating2) AND (color1 or color2)
last edit : 23/11/2017 11:50 France
Post by xnview » Thu Nov 23, 2017 11:53 am
jadO wrote:In the categories pane if you select a category plus a rating for filtering, no files are shown.
category+rating works for me
jadO
Post by jadO » Fri Nov 24, 2017 7:52 am
Weird. I have jsut tried it again and it is not working. Here is what I am doing:
1. Select a folder.
2. In categories pane set match drop down to "All" and "Current folder (Recursive)"
3. Select 1 category
4. Check that there are results with rating displayed
5. Select a rating from categories pane with STRG pressed
Result: No more files getting displayed.
If I add a color marking with STRG pressed, then results show properly rated files with color markings.
Post by xnview » Sun Nov 26, 2017 3:16 pm
:bugconfirmed: Thanks to your detailed description I can reproduce the problem with "Current folder"
Post by xnview » Sat Dec 30, 2017 2:44 pm
This problem is supposed to be fixed in XnView MP 0.89. Please check and confirm the bug fix here.
Post by michel038 » Thu Jan 18, 2018 10:05 pm
Version V0.89
When we select "Match" Current folder , or Current folder recursive,
Category + rating = working properly
Category + color label = working properly
Tag + category = working properly
But if we select Match, Global, result is always 0 images.
The bug remains in this case.
Post by xnview » Fri Jan 19, 2018 9:04 am
michel038 wrote: But if we select Match, Global, result is always 0 images.
right
Post by xnview » Mon Feb 12, 2018 10:13 am
This problem is supposed to be fixed in XnView MP 0.90. Please check and confirm the bug fix here.
Post by michel038 » Mon Feb 19, 2018 5:53 pm
Yes, fixed
Thank you
We can select many items and wait for result : It's ok
But all items must be un-selected before trying to select other items, otherwise the selected items will mix a little.
