you don't need this plugin, 0.99.1 have heic plugin support by defaultArvalon wrote: Sun Oct 17, 2021 1:57 pm x86 version shows heic and the x64 does not. Updated the plugin for the x64 version.
Windows 10 Pro
version 21H1
Build 19043.1288
Plugins and Addons
Re: Plugins
Re: Plugins
Not sure, previously all things worked ok when tried to open apple iphone photo.
May be there is because:
Re: Plugins
Could you post a file?c400 wrote: Mon Oct 18, 2021 12:38 pm Not sure, previously all things worked ok when tried to open apple iphone photo.
By default, it doesn't use anymore the windows codec![]()
Re: Plugins
https://dropmefiles.com/pjfkj
and i can see previews
Installing https://www.microsoft.com/en-us/p/heif- ... verviewtab solves the problem
Re: Plugins
also found out that when file is located in a directory with russian letters and spaces, the file does not opens. But it is enough to drop it 4 example on the desktop and everything works fine!c400 wrote: Tue Oct 19, 2021 12:49 am Installing https://www.microsoft.com/en-us/p/heif- ... verviewtab solves the problem
Re: Plugins
Is there a way to get HEIF working on Linux? Doesn't work for me on 0.99.1.
Re: Plugins
Is the Face Recognition plugin supposed to work on MacOS?
I created an "Addons" folder in the XnView package (/contents/Addons) and unzipped the content of the zip (FaceTag folder) in it, but "Tag Faces" is still gray in the menu.
Since there is another plugin folder in the package I also tried to put the FaceTag folder in /contents/MacOS/Addons without any luck...
Re: Plugins
Currently only supported on Windows, but soon for MacOSNicolas wrote: Fri Dec 03, 2021 3:16 pm Is the Face Recognition plugin supposed to work on MacOS?
Re: Plugins
OK, thanks Pierre! Is it why it's a separate download rather than included in the main app? I wondered why...
Re: Plugins and Addons
Why are there two plugins directories inside the macOS App? This is so confusing. In which one should I place the plugins?
you have plugins for QT and plugins for XnView, but which plugin do you want to add?sd_snatcher wrote: Sun Feb 12, 2023 12:05 am
Re: Plugins
I have just downloaded XnView for MacOS (Ventura), and I see the add-on for Face Tag is only for Windows. Is there a plan to put it in MacOS version ? The function is in grey in the menu. Thanks for your information.xnview wrote: Fri Dec 03, 2021 3:47 pmCurrently only supported on Windows, but soon for MacOSNicolas wrote: Fri Dec 03, 2021 3:16 pm Is the Face Recognition plugin supposed to work on MacOS?
Re: Plugins
yes, it's plannedMireille wrote: Tue Feb 28, 2023 7:03 pm I have just downloaded XnView for MacOS (Ventura), and I see the add-on for Face Tag is only for Windows. Is there a plan to put it in MacOS version ? The function is in grey in the menu. Thanks for your information.
