Plugins and Addons
ianas
Re: Plugins
Post by ianas »
xnview wrote: Mon Dec 04, 2017 12:05 pm
yes but they pay perhaps the patent ;)
the latest GIMP added heif import/export support I doubt they payed anyone anything
https://www.gimp.org/news/2018/05/20/gi ... age-format
apparently microsoft's added heif support in windows 10 build 17123
https://blogs.windows.com/windowsexperi ... gJHc5Q8.97
I can confirm that after downloading a codec from the microsoft store microsoft photos can open heif files as far as I can tell no write support
Re: Plugins
ianas wrote: Mon Sep 17, 2018 5:39 pm I can confirm that after downloading a codec from the microsoft store microsoft photos can open heif files as far as I can tell no write support
yes but libx265 is only in GPL license not LGPL :(
ianas
Re: Plugins
Post by ianas »
xnview wrote: Tue Sep 18, 2018 8:56 am
I understand that the GPL is extremely restrictive
to be clear the plugin is read only with no write support are there plans for write support?
one of the reasons jpeg stuck around for so long was the lack of patent restrictions (almost)
talking patents and jpeg the arithmetic coding patent has ended and libjpeg-turbo already has arithmetic coding support and XnView MP can read arithmetically encoded jpeg's can we get write support (a check box use arithmetic instead of Huffman coding)
bucky
Re: Plugins
Post by bucky »
xnview wrote: - HEIF format x32 bits and x64 bits
Looks like those are Windows DLLs. Any XnView MP plugins for Mac that support HEIF / HEIC files?
Re: Plugins
bucky wrote: Mon Dec 31, 2018 9:39 am Looks like those are Windows DLLs. Any XnView MP plugins for Mac that support HEIF / HEIC files?
Next version for MacOSX will support natively HEIC
b01d
Re: Plugins
Post by b01d »
xnview wrote: Tue Jan 01, 2019 1:52 pm
0.93? Or other?
Re: Plugins
b01d wrote: Sun Feb 03, 2019 10:47 am
0.93? Or other?
yes 0.93 Mac
Tapio
Re: Plugins
Post by Tapio »
This is still the way to go on Windows 7, right? My problem is, XNViewMP loves to crash on some heic files. Under whatever circumstances. Don't know yet...
LaMpiR
Re: Plugins
Post by LaMpiR »
Hi. I have downloaded the plugins, unzipped them to the plugins folder. It's not working and I cannot see them in the Plugin list?
Re: Plugins
LaMpiR wrote: Wed Mar 25, 2020 11:34 am Hi. I have downloaded the plugins, unzipped them to the plugins folder. It's not working and I cannot see them in the Plugin list?
which plugin?
ECCX25519
Re: Plugins
Post by ECCX25519 »
Hello, I'm having trouble getting heic files to work as well, I've extracted the HEIF format into the [C:\Program Files\XnViewMP\plugins] folder but XNView MP still can't read the files.
Also the link to XpackRAW is down, I get a 'not found' error when I try to go there, so do you have a backup link/ copy of that plugin?
Thanks!
Re: Plugins
ECCX25519 wrote: Sat Apr 04, 2020 4:12 am Hello, I'm having trouble getting heic files to work as well, I've extracted the HEIF format into the [C:\Program Files\XnViewMP\plugins] folder but XNView MP still can't read the files.
No HEIF files are readed? Perhaps the better solution is to install via Microsoft Store, the HEIF plugin, Xnview will use it
Right, but i'm not having a copy :(
ECCX25519
Re: Plugins
Post by ECCX25519 »
I have the HEIC and HEVC plugin from Windows store but Xnview doesn't seem to make use of it. The windows photo app does work though.
Re: Plugins
ECCX25519 wrote: Mon Apr 06, 2020 11:35 pm I have the HEIC and HEVC plugin from Windows store but Xnview doesn't seem to make use of it. The windows photo app does work though.
do you have removed the heic plugin from Plugins folder?
ECCX25519
Re: Plugins
Post by ECCX25519 »
Yes I deleted the plugin; I tried reinstalling the HEIC and HEVC plugins from MS store then reinstalling Xnview
