Plugins and Addons
Plugins and Addons
Plugins (must be in 'plugins' directory)
- QOI format by Piotr Fusik
- XPackRAW by Márcio Pais
- HEIF format x32 bits and x64 bits
Addons (must be in 'AddOn' directory)
- Face tags/Face regions
Re: Plugins
it will be shipped with the next version?
m. Th.
Re: Plugins
no, currently patents are not clearm.Th. wrote:it will be shipped with the next version?
Re: Plugins
m. Th.
Re: Plugins
Any chance of getting windows explorer thumbnails previews somehow ?
Re: Plugins
Should this work in Windows 10 64bit? For me, it doesnt.
Olympus OMD E-M1, BS Kinetics underwater housing, 2xSubtronic pro 160 flashes. Zuiko mFT lenses: 60 macro, 7-14, 8 mm fisheye, 12-100, PanaLeica 100-400.
My Homepage | My book at Amazon
Re: Plugins
I tried it with several .heic files I found online, for example with the free example from here:
https://www.online-convert.com/file-format/heic
I copied the heif.dll in the /plugin folder. I also tried it by moving it to the XnViewMP program folder. Both attempts failed. I am using the XnViewMP version without installer (just unzipped).
Regards,
Jens
Regards,
Jens
Re: Plugins
The plugin is for HEIC from Apple not Nokia standardTschens wrote: Mon May 14, 2018 5:55 pm I tried it with several .heic files I found online, for example with the free example from here:
Re: Plugins
I put it in Plugins folder but it doesn't appear on About->Plugins
Re: Plugins
I can confirm that it does not appear in the about-> plugins window but I did download a few test images fromarch21 wrote: Fri Sep 14, 2018 1:52 pm I put it in Plugins folder but it doesn't appear on About->Plugins
https://github.com/liuziangexit/HEIF-Ut ... r/Examples
and XnView MP does open them with the heif plugin
it's not mentioned in the first post or in the plugin's readme file but this plugin is read only right there is no heic write support?
is it possible to add write support?
what about the bpg plugin if both heif and bpg are based on h265 i frames wouldn't the patent issues be the same for both of them?
