0.88: Strange behavior of the Show information toggle button
Older bugs which are supposed to be fixed in 0.84. *** Please try to reproduce your bug and confirm the bug fix. ***
Moderator: Dreamer
miki
Post by miki » Fri Nov 10, 2017 5:10 pm
XnView: MP 0.88 - 64 bit
OS: Windows 10 - 64bit
The toggle state of the Show information button (cmd_showInfo) in the viewer toolbar gets out of sync.
Effect: The Show information button appears to be toggled on, but the info panel is not there, especially after getting from fullscreen mode. On the other side, when opening a picture from browser, the info panel is visible, but the toggle button is off.
1. Place Show Information button (cmd_showInfo) to the viewer toolbar.
2. Toggle the button on to display info.
3. Go to fullscreen and return... the info panel disappears while the button is still toggled on.
4. Or open a picture from the browser and the button toggle state can get out of sync as well.
Actual behaviour (bug): The toggle state of the Show information button gets out of sync.
Expected behaviour: The toggle state should correspond the info panel visibility
Miki Proxima (meshlogic)
Re: 0.88: Strange behavior of the Show information toggle button
Post by xnview » Sun Nov 12, 2017 11:52 am
Post by xnview » Wed Jan 24, 2018 1:00 pm
See issue for current status and some details. I'll post here once the problem has been fixed.
Post by xnview » Mon Feb 12, 2018 10:13 am
This problem is supposed to be fixed in XnView MP 0.90. Please check and confirm the bug fix here.
miki
Post by miki » Tue Feb 20, 2018 11:42 am
I have tried 0.90 beta 1, but the Show information toggle button still doesn't work consistently for me:
1. I open an image in the viewer (from the browser) and toggle the Show information on.
2. I close the image and open it again. Then, the info is displayed, but the toolbar button is toggled off.
Post by xnview » Thu Jun 07, 2018 9:47 am
This problem is supposed to be fixed in XnView MP 0.91. Please check and confirm the bug fix here.
