0.88 : "Compare" icon is inactive
Moderator: Dreamer
kimys
Post by kimys » Thu Nov 09, 2017 1:09 pm
In XnView Classic, Tagging multiple images lead to activate "Compare" menu.
But in XnView MP, "Compare" menu is still inactive.
Please fix it next revision.
Re: 0.88 : "Compare" icon is inactive
Post by xnview » Thu Nov 09, 2017 1:25 pm
it's the same problem with batch convert/rename/...
kimys
Post by kimys » Thu Nov 09, 2017 5:04 pm
Send by email
Print
Contact Sheet
Batch Convert
Compare
Flip horizontal
Flip vertical
Rotate clockwise
Rotate counter clockwise
Batch rename
Delete
You are right !!!
All above functions are inactive.
Moderator & Librarian
Post by XnTriq » Wed Oct 16, 2019 1:00 am
This needs fixing.
kaon wrote:
Sat Jul 09, 2011 11:56 am
In case anyone cannot find the Tools > Compare ,
It isn't available in the Tools menu in the XnView Viewer.
It is initially greyed out in the Tools menu of the Browser.
CTRL-Click to select up to four thumbnails in the browser first, then the Compare will be available. (It will also be available in context menu).
2fnojx8zimg4 wrote:
Fri Sep 21, 2018 9:49 pm
This is grayed out. How do I use this feature, please?
Hoyoen1 wrote:
Mon Oct 14, 2019 2:35 pm
XnTriq wrote:
Thu Aug 30, 2012 11:00 pm
Select two or more images in the browser and go to Tools » Compare... (Shift+C) for synchronized side-by-side panning & zooming.
I tried this option but when I go to tools, compare, the option is gray and I cannot select it. Any suggestion?
I haven't been able to reproduce this myself, though :-|
