0.87: Default Drag&Drop behavior
Older bugs which are supposed to be fixed in 0.84. *** Please try to reproduce your bug and confirm the bug fix. ***
Moderator: Dreamer
Teknova
Post by Teknova » Thu Nov 02, 2017 9:53 am
XnView: MP 0.87 - 64 bit
OS: Linux Mint18.2 - 64bit
When Drag&Dropping files, the default behavior is to Copy instead of Move.
Effect: When sorting files it is extremely time consuming to have to constantly keep holding down Shift in order to move files on the same drive/folder subtree.
1. Left-click and drag a file from the main window into the Directory tree into a Folder on the same drive.
Actual behavior (bug): Copies
Expected behavior: Moves
Also, I tried messing with the "Mouse" controls on the menu and they seem to have no effect at all.
P.S. I tried a clean install (complete removal + delete config and db files). Still no luck.
Re: 0.87: Default Drag&Drop behavior
Post by xnview » Mon Nov 06, 2017 9:49 am
:bugconfirmed: Thanks to your detailed description I could reproduce the problem.
Post by xnview » Thu Jun 07, 2018 9:47 am
This problem is supposed to be fixed in XnView MP 0.91. Please check and confirm the bug fix here.
