Deleting a file in View mode
TheEvilHammer
Post by TheEvilHammer »
When you delete a file in view mode, XnView rewinds to the beginning of the file list and displays the first file. Shouldn't it display the file after the one deleted?
Lesmo16
Re: Deleting a file in View mode
Post by Lesmo16 »
TheEvilHammer wrote:Shouldn't it display the file after the one deleted?
IMO it should! :wink:
Everyone who believes in telekinesis, raise my hand!
TheEvilHammer wrote:When you delete a file in view mode, XnView rewinds to the beginning of the file list and displays the first file. Shouldn't it display the file after the one deleted?
In view mode? Are you sure, i can't reproduce this bug...
TheEvilHammer
You know what, neither can i... :D
I'm not sure how I did it before, but XnView was definitely rewinding to the beginning of the list of files. When I try deleting a file now, it goes to the next file as it should. If I see it happen again in the future, I'll try to figure out exactly what I was doing differently. Does anyone else know how to make this happen?
I do have a new suggestion though - if you are in "view" mode, and you are viewing the only file in a directory, and you delete it, I think it makes sense to automatically close up the current "tab" and shift focus to the previous tab.
What do other people think?
