0.87 / Win 10: "Open with" path parsing
Older bugs which are supposed to be fixed in 0.84. *** Please try to reproduce your bug and confirm the bug fix. ***
Moderator: Dreamer
dergilbwillspam
Post by dergilbwillspam » Fri Oct 27, 2017 1:59 pm
XnView MP: Version 0.87 64bits (Sep 7 2017)
OS: Windows 10 Pro FCU 64bit
"Open with" fails if path contains percent sign followed by number.
Effect: Target program doesn't open file.
1. Have a path like d:\%1\test.jpg
2. Have a program like MSPaint or Paint.NET configured in "Open with" in XnView
3. Try to open the file in target program with "Open with"
Actual behavior (bug): Target program doesn't open the file because path is not parsed correctly. :bug:
Expected behavior: Target program opens the file
Re: 0.87 / Win 10: "Open with" path parsing
Post by xnview » Sun Oct 29, 2017 2:40 pm
Post by xnview » Fri Nov 03, 2017 1:04 pm
This problem is supposed to be fixed in XnView MP 0.88. Please check and confirm the bug fix here.
dergilbwillspam
Post by dergilbwillspam » Tue Nov 14, 2017 1:55 am
Clicking the programs works now, but the "Open with" shortcuts (alt + number) still do not (same error as before: File not found.) :bug:
Sorry for not being able to respond sooner.
Post by xnview » Wed Nov 15, 2017 1:43 pm
dergilbwillspam wrote: Clicking the programs works now, but the "Open with" shortcuts (alt + number) still do not (same error as before: File not found.) :bug:
No problem with shortcut in browser mode, but can't be opened in edit mode
dergilbwillspam
Post by dergilbwillspam » Wed Nov 15, 2017 4:08 pm
I didn't notice this, but you're right.
Post by xnview » Sat Dec 30, 2017 2:45 pm
This problem is supposed to be fixed in XnView MP 0.89. Please check and confirm the bug fix here.
dergilbwillspam
Post by dergilbwillspam » Wed Aug 15, 2018 2:37 pm
Oops, sorry. There's still a problem. Trying to pinpoint it right now.
[Edit: Update to 0.90 fixed this second error I had with 0.89. Thank you!]
Post by xnview » Wed Aug 29, 2018 7:52 am
which problem?
