"Text Settings" Dialog: Buttons not aligned
TheEvilHammer
Post by TheEvilHammer »
Just figured I'd let you know: In the "Text Settings" dialog (within Options->View->Fullscreen), the OK and Cancel buttons are not located at the same height (quite noticably).
TheEvilHammer
I just realized this also applies to the "Text Settings" dialog in Options->Slide show.
V
Post by V »
Please fix, I have to turn my monitor 20 degrees just to use it...and its too heavy.
Lesmo16
Post by Lesmo16 »
V wrote:Please fix, I have to turn my monitor 20 degrees just to use it...and its too heavy.
Yes you're right, it should be fixed - although your post was ironic.
It's easily to fix, and the look&feel would go more perfect.
[OT]
If you find a scratch at your brand new car - don't worry about it!
Even with the scratch the car does everything it should do, right?
Don't look at it, or put a nice sticker on it. :mrgreen:
[/OT]
Everyone who believes in telekinesis, raise my hand!
Re: "Text Settings" Dialog Ugliness
TheEvilHammer wrote:Just figured I'd let you know: In the "Text Settings" dialog (within Options->View->Fullscreen), the OK and Cancel buttons are not located at the same height (quite noticably).
Oh yes, i don't know why ??? :-)
