changing windows dimensions???
Moderators: XnTriq, xnview
alphamember
Post by alphamember » Sun Oct 22, 2017 8:22 am
I have downloaded the latest version of XnView. I want to open more images at a time so I can compare them. They open but the windows can't be dragged smaller. So I can't order the opened photos next to each other. Normally if you put the cursor over the frame of a windows you can drag the frame to the left or the right or up or down. Little arrows appear when the cursor is placed over the window frames. But there are no arrows in my XnView windows. The same happens with the browser. How to solve? Thx.
Re: changing windows dimensions???
Post by xnview » Sun Oct 22, 2017 8:24 am
the dialog size is fixed (you can change it only in XnView MP)
alphamember
Post by alphamember » Sun Oct 22, 2017 8:29 am
Thank you Pierre. I had to reinstall my PC because of a fatal error. I installed the same XnView I thought so at least. I could formerly change the size of the opened photo windows. I used it daily. Now the window size stay fixed. Is it because I installed the wrong XnView version then?
I just installed XnView MP but there I can open just one photo at a time.
best regards
Rob
Post by xnview » Tue Oct 24, 2017 1:23 pm
alphamember wrote: I just installed XnView MP but there I can open just one photo at a time.
you can open more than 1 photo in tabs like XnView Classic
alphamember
Post by alphamember » Thu Oct 26, 2017 1:47 pm
Hi Pierre,
yes I know that you can open more than one photo, each in their own window. But the problem is I can't change the dimension of those windows. I could in the past but not anymore. Do I have to change something in the settings?
Best regards
Rob
Post by xnview » Fri Oct 27, 2017 12:15 pm
alphamember wrote: yes I know that you can open more than one photo, each in their own window. But the problem is I can't change the dimension of those windows. I could in the past but not anymore. Do I have to change something in the settings?
in XnViewMP? could you post a screenshot?
