TIF: XNView-Compression: double size as other software
Moderators: XnTriq, xnview
Peter2
Post by Peter2 » Fri Oct 20, 2017 7:45 am
I have a TIF, 257 colors, 406 MB uncompressed.
When I use "LZW compression" with
- XNview 2.42, I get a file with 3.6 MB
- another software, I get 1.1 MB file
When I compare both results, they seem to be the same: size, color, DPI, compression, .....
Where is the difference?
xxx.7z
(55.53 KiB) Downloaded 32 times
XnView 2.48 German, Win 7 x64 Prof. / Win 10
Re: TIF: XNView-Compression: double size as other software
Post by xnview » Fri Oct 20, 2017 11:37 am
Other software use different Predictor
Peter2
Post by Peter2 » Fri Oct 20, 2017 12:36 pm
Thanks Pierre
but for the user, the result - beside the filesize - is the same? DPI, colors, size, quality, ..
Post by xnview » Fri Oct 20, 2017 1:28 pm
Peter2 wrote:Thanks Pierre
yes same image
