File extension
funben
File extension
Post by funben »
In XnConvert 1.75, when converting to another format, the extension is kept as the original. For instance, I have a bunch of JPG files that I want in PNG 256 colors.
the output file extension is kept as JPG.
by using {Filename}.png in the "output filename" field result in IMG2367.png.jpg
The best way I found was to convert the file, and then using another software to rename it.
Thanks for the very good software :D
Merci pierre
Re: File extension
Could you post a screenshot of output tab?
funben
Re: File extension
Post by funben »
As requested, the output capture is attached
<?xml version="1.0" encoding="UTF-8"?><XnView_script version="1.0" name="ConvertParam">
<Change_color_depth method="1" dither="5" ncompo="256" alpha="255"/>
<Output folder="" filename="{Filename}.png" case="0" startIndex="1" format="PNG">
<Options overwrite="0" orgDate="false" keepMeta="false" keepICC="false" keepFolder="false" keepParentFolder="false" delOrg="false" multipage="false" allPages="false" openExplorer="false" openBrowser="false" clearItems="false"/>
<PNG level="9" interlaced="false" filter="0"/>
</Output>
</XnView_script>
funben
Re: File extension
Post by funben »
I tried every combination, and didn't find the trick, I just tried to find an former version, but I didn't find it.
To me it is not a misuse ... it is a bug
Re: File extension
i can't reproduce, could you post the screen 'Status'? And if you use '{Filename}'?
funben
Re: File extension
Post by funben »
Here are the output and status screenshot. If you want you can access my computer. I'll send you the details in PM
funben
Re: File extension
Post by funben »
I just tried with 1.70 version, and this is the same.
I used {Filename With Ext}
Here is the status screenshot
funben
Re: File extension
Post by funben »
I just did a new test ... and I know what i could be coming from.
The files I use is a PNG file that has been renamed as JPG by another software.
I tried with a proper JPG file and extension has been changed as PNG as it should be.
It is not fully a bug, but I cannot correct with this XnConvert, what the other software did wrong
Re: File extension
funben wrote:I just did a new test ... and I know what i could be coming from.
Right, in this case XnConvert use the good extension, so not really a bug...
funben
Re: File extension
Post by funben »
It is not really a bug but still the output file extension is wrong. It would be nice if you could figure something out to have a clean file after the convert process.
Spriggana
Re: File extension
Post by Spriggana »
I just came to address the same issue, and I'd say it is a minor bug.
If I feed xnconvert a jpg-with-png-extension file and ask for it to be converted to png I get a proper png file with png extension.
But if I ask for a jpg file I get a proper jpg file with png extension which is confusing…
Why would xnconvert leave the incorrect extension in place if actual source file format matches the required output one instead of simply changing the extension to match the output format?
ramses
Re: File extension
Post by ramses »
Same issue.
I have a lot of files xxx.jpg but they are really tiff files. So I use XnConvert whitout action, whith {Filename} and Tiff format. I hope to get xxx.tif but it's still xxx.jpg
So I take 4 files to test all the cases: realjpg.jpg realjpg.tif realtif.jpg and realtif.tif
All of them are well display by XnWiev because I think you look at the format inside the file, not with extension. But more simple wiever don't do, so realjpg.tif or realtif.jpg are not readable.
With the use of XnConvert, and the above parameters, I get:
realjpg.jpg become -> realjpg.tif good tif readable :D
realjpg.tif -> realjpg.tif good tif readable :D
realtif.jpg -> realtif.jpg wrong jpg really tif not readable :evil:
realtif.tif -> realtif.tif good tif readable :D
It seems as if you don't add the extension when the format is yet the good one, doesn't matter the extension, because may be you don't convert in this case. And the name is unchanged.
Jean
LinuxMint 15 / XnView MP 0.64
