0.87: Horizontal selection handlers and fixed ratio
fbusson
Post by fbusson »
XnView: MP 0.87 - 64 bit
OS: Windows 10 64bit
When a selection has a fixed ratio (like the image), it can't be resized with the mouse using the left or right handler, but it works with the vertical or diagonal ones. It's only a problem with this particular ratio.
1. Open an image in the view mode
2. Edit -> Ratio -> Like the image
3. Draw a selection with the mouse
4. Try to resize it with the left or right handler
Actual behaviour (bug): nothing happens
Expected behaviour: the right or left handler should behave like the others
Thank you,
Re: 0.87: Horizontal selection handlers and fixed ratio
sorry but it works for me
fbusson
Post by fbusson »
I made a little video :
http://www.mediafire.com/file/ucouxrjva ... ection.gif
I've just reinstalled XnView MP but still got the same behaviour.
But everything goes back to normal when I don't choose this particular ratio first but in second.
Thanks,
:bugconfirmed: Thanks to your detailed description I can reproduce it
This problem is supposed to be fixed in XnView MP 0.91. Please check and confirm the bug fix here.
