0.87: XnView MP crashes when saving as Guetzli JPEG
Moderator: Dreamer
Optic
Post by Optic » Sun Oct 15, 2017 5:45 am
Hi, as per topic title.
On Windows 10 64 bit, zip version of XnView MP 0.87
File > Save As > Guetzli JPEG
Saving box appears:
Progress bar quickly reaches end and doesn't progress even after 2-3 minutes.
If you press Esc key then XnView MP crashes:
Windows Event Viewer log:
Faulting application name: xnviewmp.exe, version: 0.87.0.0, time stamp: 0x59b0e7ea
Faulting module name: MSVCR120.dll, version: 12.0.21005.1, time stamp: 0x524f83ff
Exception code: 0xc0000409
Fault offset: 0x0000000000074a30
Faulting process id: 0x1860
Faulting application start time: 0x01d345769c4b43cf
Faulting application path: C:\XnViewMP\xnviewmp.exe
Faulting module path: C:\XnViewMP\MSVCR120.dll
Report Id: f97aa9d5-c4dc-4c33-8496-ca13c8a12437
Faulting package full name:
Faulting package-relative application ID:
I tried using a JPEG and also a TIFF with same result. Activity Monitor shows no CPU usage being used by XnView MP when I do the Save As to Guetzli JPEG..
pokuly
Re: 0.87: XnView MP crashes when saving as Guetzli JPEG
Post by pokuly » Sun Oct 15, 2017 3:34 pm
It may simply not done with processing. guetzli needs lots of processing time. 2-3 minutes is normal even for small 2 megapixel pics here with a 4.4GHz machine.
Optic
Post by Optic » Mon Oct 16, 2017 3:13 am
Hi pokuly
Thanks for your reply.
Yes you're right, I left it longer (10+ minutes) and it did complete successfully.
Maybe in future possible to implement a more accurate Saving picture progress bar?
Or perhaps also allow it to be used for Bulk Export / File > Export.
pokuly
Post by pokuly » Mon Oct 16, 2017 3:04 pm
Interesting that this was it. It shouldn't crash ending the process with simply hitting ESC imho.
I'd suggest to not use guetzli at this point. It seems to reduce quality to much when used in MP.
Have a look here: viewtopic.php?f=62&t=36099#p144737
I suggest some extra settings would be nice like memlimit M, nomemlimit and soon preserve-exif, cuda or OpenCL support.
