Field values are not loaded because 'Do not load field values' is checked
Moderators: XnTriq, xnview
ewml
Post by ewml » Fri Oct 06, 2017 7:35 pm
Hallo zusammen,
ich bekomme folgende Meldung, wenn ich mehrere Dateien bearbeiten möchte:
bisherige iptc daten werden nicht laden
Kann mir jemand sagen, wo ich die Einstellung finde? Irgendwie bin ich da blind und finde sie nicht.
Danke euch.
Re: bisherige iptc daten werden nicht laden
Post by xnview » Sat Oct 07, 2017 10:50 am
when you want to apply?
ewml
Post by ewml » Sat Oct 07, 2017 7:05 pm
No, when i want to open the files. The files don't show me the keywords i done before. The program told me, its not possible to load the old iptc data.
Post by cday » Sat Oct 07, 2017 7:35 pm
ewml wrote:No, when i want to open the files. The files don't show me the keywords i done before. The program told me, its not possible to load the old iptc data.
Can you upload a file with old IPTC that can not be read? [2 MiB maximum, in a ZIP or similar archive if the file format is not allowed for direct upload].
I'm not very familiar with IPTC, but someone else may be able to help...
ewml
Post by ewml » Sun Oct 08, 2017 6:15 pm
thanks for your help. I made a screenshot from the fault. Maybe it will be help you. I switch the language from German to english.
If it not help, i will upload a picture ;o)
Bildschirmfoto 2017-10-08 um 20.12.13.png (29.32 KiB) Viewed 721 times
Moderator & Librarian
Post by XnTriq » Sun Oct 08, 2017 7:30 pm
Willkommen im Forum, ewml (-:
ewml wrote:Kann mir jemand sagen, wo ich die Einstellung finde? Irgendwie bin ich da blind und finde sie nicht.
  • English
    • ToolsMetadataEdit IPTC/XMP...OptionsMultiple Selection
  • Deutsch
    • WerkzeugeMetadatenIPTC/XMP bearbeiten...EinstellungenMehrfachauswahl
See also:
xnview ([url=http://newsgroup.xnview.com/viewtopic.php?p=137827#p137827]0.84: IPTC window: Wrong workflow with multi-selection[/url]) wrote:
m.Th. wrote:3. When we open the IPTC window with "Always Clear All Fields" unchecked and we check it, nothing happens. Very, very confusing. We have already the {Clear all fields} for this. Perhaps "Always clear all fields" should be renamed to "Do not load field values", UNCHECK it by default, and if it is checked then for every file do not load the field values?
yes 'do not load field values' is better. But need TRUE by default, in the past users have always problem to 'save all ' changes if prload of fields was made...
ewml
Re: Field values are not loaded because 'Do not load field values' is checked
Post by ewml » Mon Oct 09, 2017 8:05 pm
Many Thanks. Just found it ;o)
