0.87: Renaming a folder with a non-ASCII character name corrupts the database
Older bugs which are supposed to be fixed in 0.84. *** Please try to reproduce your bug and confirm the bug fix. ***
Moderator: Dreamer
shokuzai
Post by shokuzai » Thu Oct 05, 2017 9:35 pm
XnView: MP 0.87 - 64 bit
OS: Windows 10 - 64bit
Effect: Corrupted database
Detail:
- The category assignments and the tags are removed from the files inside the folder.
- But those files are still shown when browsing through Categories Filter.
- In Setting -> Catalog -> Catalog -> Cached directory, two entries are created, for example:
D:\Pictures\漢字 (without backslash)
D:\Pictures\漢字\ (with backslash)
where 漢字 is the new name.
What are affected: folders whose names consist of non-ASCII characters, namely 漢字(Chinese characters) and かな(kana).
Rename any of those folders to another such name inside XnView MP.
Re: 0.87: Renaming a folder with a non-ASCII character name corrupts the database
Post by xnview » Thu Oct 12, 2017 12:30 pm
:bugconfirmed: Thanks to your detailed description I can reproduce the problem. Even for ascii name!
Post by xnview » Fri Nov 03, 2017 1:05 pm
This problem is supposed to be fixed in XnView MP 0.88. Please check and confirm the bug fix here.
miki
Post by miki » Mon Nov 13, 2017 5:03 pm
Hello, i'm using version 0.88 and just trying to learn how to work with the catalog and it seems this bug is still there.
When I rename a "middle" folder in the pictures path (e.g. /parent/folder/pics/x.jpg -> /parent/folder2/pics/x.jpg), all the categories are lost for the files in the folder pics. They are still visible in the Categories Filter, but as invalid-lost files.
So, renaming seems to work only when the last folder in the path is renamed (e.g. /pics/x.jpg -> /pics2/x.jpg)... renaming any middle folder in the path corrupts the catalog.
Btw, is there any option to rebuild the catalog manually when folders are renamed/moved in another file manager? I tried the Optimize button in the Settings-Catalog, but no luck.
EDIT: I found a temporary workaround. I create a brand new folder with the desired name, then move there all the subfolders from the old folder. But of course, this is a cumbersome workflow for just renaming a folder.
Miki Proxima (meshlogic)
Post by xnview » Tue Nov 14, 2017 11:52 am
miki wrote: When I rename a "middle" folder in the pictures path (e.g. /parent/folder/pics/x.jpg -> /parent/folder2/pics/x.jpg), all the categories are lost for the files in the folder pics. They are still visible in the Categories Filter, but as invalid-lost files.
Right the previous fix was the problem, so here is the bug report
miki
Post by miki » Tue Nov 14, 2017 1:01 pm
xnview wrote: Right the previous fix was the problem, so here is the bug report
Thank you very much for fixing this essential issue :) Is there a place to download the current beta/development version for testing?
Post by xnview » Sat Dec 30, 2017 2:45 pm
This problem is supposed to be fixed in XnView MP 0.89. Please check and confirm the bug fix here.
ele123
Post by ele123 » Fri Jul 19, 2019 4:25 pm
Same problem, the bug still exists, v0.93.1
Post by xnview » Sat Jul 20, 2019 3:41 pm
how do you reproduce?
ele123
Post by ele123 » Sat Jul 20, 2019 9:17 pm
Thank you for your response. This bug may be related to Chinese characters.
1, Create folders (one in Chinese) and put some pictures in them, like this:
  文件夹1 / folder2 / pic1.jpg
  ("文件夹" means folder)
2, Set all images some categories.
3, Rename "文件夹1" , and an error window will pop up "Error / An error occurs during rename!".
4, Restart the software and rename "文件夹1" again, now I lost "pic1.jpg" 's category.
5, If create the folder like this:
  文件夹1 / folder2┌ folder3 / pic1.jpg
 and rename "folder2" , both pic1 and pic2 categories are lost. (-win10/1903, xnviewmp/v0.93.1 64bits, Sorry for my English.
Post by xnview » Fri Aug 09, 2019 8:16 am
I've sent a PM
