Search my threads only
General info, hints, guidelines and rules for all XnView forums. Guests and new users please read here first.
mrwul
Post by mrwul »
Is there a way to search my -own- threads only, i.e. in the same way as the default search?
I can search on my forum username
OR
I can search on a specific string but not limited to my username.
Reason is that I discovered that once XnViewMP is already running, I could open an email-attachment until I closed XnViewMP
first. Checking out the settings I noticed that 'Allow only one instance of XnView' was enabled.
Disabling that option solved the problem.
However, I do have the feeling that I tagged that option myself for one reason or the other.. probably based on an issue reported here.
I don't know for sure though.
Reason why I wanted to check whether any threads that I started/participated in was dealing with this so it would tell me -why- I had
this option tagged, IF at all I indeed tagged it.
Thanks
Moderator & Librarian
Re: Search my threads only
Hi, mrwul (-:
Unfortunately phpBB's built-in search isn't capable of that.
mrwul
Post by mrwul »
XnTriq wrote:Hi, mrwul (-:
Thanks! Probably I only read it, in some thread or so, i.e. not one that I have been participating in.
Anyway I untagged that option and see what happens.
Maybe I will stumble over the same issue again (whatever that might have been) that made me tag that option.
Anyway, thanks again.
