pHash (perceptual hash) for duplicates & similar
Goulu
Post by Goulu »
I suggest indexing all images in the database by a "perceptual hash" . See here : http://www.hackerfactor.com/blog/?/arch ... ke-It.html it's extremely simple and fast. There is a library here to do it : https://www.phash.org/
I use it for a professional project and it's incredible : with a 32 bits key, you can instantaneously (well O(log N) ...) find duplicates in hundreds of thousands of images. And very quickly find similar images.
Since XnView already builds a database, I think this feature would make it the fastest duplicates and similar image finder on Earth. :D
Re: pHash (perceptual hash) for duplicates & similar
thanks, i'll check it
m.Th.
Post by m.Th. »
m. Th.
jadO
Post by jadO »
xnview wrote: Mon Oct 02, 2017 7:24 am thanks, i'll check it
Will that be built into XnViewMP?
yes usefull, but to create it, i need to load image
jadO
Post by jadO »
xnview wrote: Tue Mar 16, 2021 3:15 pm yes usefull, but to create it, i need to load image
Is that a problem? From my understanding when a creating thumbnails, the image must be loaded too. So why not combining thumbnailing with hashing?
jadO wrote: Fri Jul 30, 2021 7:51 am
No, image is not always loaded, when embedded thumbnail is available or small preview
