XnConvert 1.75
XnConvert 1.75
XnConvert MP (XnView batch convert as multi-platform standalone program) is available.
You can download XnConvert here
Windows x32 Setup Windows x64 Setup
Windows x32 ZIP Windows x64 ZIP
MacOSX x64 DMG MacOSX x64 TGZ
Linux x32 TGZ Linux x64 TGZ
Linux x32 DEB Linux x64 DEB
Linux x32 RPM Linux x64 RPM
For ArchLinux/Gentoo/Manjaro distribution, please replace the executable with
Linux 32bits Linux 64bits
http://itunes.apple.com/app/xnconvert/id436203431?mt=12
Changelog:
* Many bugs fixed
You can use
XnConvert file1 file3 file3
or
XnConvert @filelist
Danny
Re: XnConvert 1.75
Post by Danny »
The 64bit TGZ archive version launches on Fedora 26, but all the text is invisible. I can mouse select it, but it doesn't show up.
Get the bugs fixed, THEN start adding features. It sucks, but someone has to do it.
Re: XnConvert 1.75
Danny wrote:The 64bit TGZ archive version launches on Fedora 26, but all the text is invisible. I can mouse select it, but it doesn't show up.
it's a problem with fontconfig
Hank
Re: XnConvert 1.75
Post by Hank »
I renamed the main fonts.conf file to old so it no longer counts:
mv /etc/fonts/fonts.conf /etc/fonts/fonts.conf.old
And XnConvert is now working, however, another application may complains:
[user@machine fonts]$ eog&
[1] 1234
[user@machine fonts]$ Fontconfig error: Cannot load default config file
So it is better to change the name back...
