Export for nconvert: shadow option does not work
jacomo
Post by jacomo »
Hi!
I am using Ubunu 16.04 and nconvert 6.88 (NConvert-linux64.tgz)
I used XnView for batch-converting with following action: "Shadow-Highlight".
Then I exported the command with "Export for NConvert..."
It shows me:
nconvert -shadow 0 100
Now I used following command:
./nconvert -shadow 0 100 -o outfile.jpg infile.jpg
Result:
Bad argument -'shadow'
What's going wrong?
Many Thanxx
Re: Export for nconvert: shadow option does not work
right, will be added in next version
jacomo
Post by jacomo »
Many thanks for your fast reply.
By the way:
I am using the filter to get a unique white background after scanning a document with black text. The filter is very good for this job because it doesn't change the colour much.
Does anybody know an alternative filter / tool (maybe with imagemagick) for the time I have to wait for the update?
Thanxx
