Update when saved
thire
Update when saved
Post by thire »
I open a picture and click to see the next one and then the little favicon in the image tab is not updated.
and when I crop and resample it and save it, in the statusbar the image size (1.4MB) is not updated.
thire
Post by thire »
anyway there seems to be something unlogic:
I change the image and save it in another folder
When I browse to the next image, I browser in the "original" folder
When I browse back then, I see the saved one in the "new" folder, but (when I look in the browser) the original image is still the "good" one... :?:
Re: update when saved
thire wrote:I open a picture and click to see the next one and then the little favicon in the image tab is not updated.
Right a bug
It's not the image size, but the file size, and right not updated
thire
Post by thire »
xnview wrote:
thire wrote:and when I crop and resample it and save it, in the statusbar the image size (1.4MB) is not updated.
Okay, I meant the filesize. And it should be updated: the star next to the image disappears when I save the image (size reduced to 100KB) and, I would say this is inconsistent (image changes, filesize not).
thire
Post by thire »
xnview wrote: It's not the image size, but the file size, and right not updated
Ah, I missunderstood you? "right" means I am right? :D
Yes :-)
