0.86 64 bits: Can’t open files with long full path
RomanM
Post by RomanM »
XnView: MP 0.86 - 64 bit
OS: Windows 10 Home single language (Russian) - 64bit
XnViewMP fails to open files with full path longer than 255 characters.
Effect: file is not opened, sometimes no error is shown, sometimes error is shown.
1. Create folder structure and place there .jpg file. Full .jpg file path must be longer than 255 characters. For example, my path is: “d:\FotoArchive\Album#2\Processed\003-Lorem ipsum dolor sit amet, consectetur adipiscing elit. Quisque pharetra nulla a lacus imperdiet commodo. Vivamus lobortis iaculis augue, a malesuada magna pretium quis. Suspendisse fermentum placerat justo, at ultrices lib.jpg” or (with Russian characters in the file name) "d:\FotoArchive\Album#2\Processed\003-Анатолий (справа), брат Воровцовой Галины Федоровны и неизвестный. Надпись на обороте На память сестре Галине от брата Анатолия в дни моей службы в Германии. Помни вечно, дарю сердечно. Зыков. Германия. 1954. Лицевая сторона.jpg"
2. Open XnView MP and navigate to the folder with the .jpg file (e.g. d:\FotoArchive\Album#2\Processed\)
3. NOTE: file preview is shown correctly!
4. Double-click on the .jpg file.
Actual behaviour (bug): nothing happens, or (if there are Russian characters in the file path) this error is shown:
Warning
Ошибка при открытие файла <D:\FotoArchive\Album#2\Processed\0>
ОК
Expected behaviour: Image is shown.
krzysiu
Re: 0.86 64 bits: Can’t open files with long full path
Post by krzysiu »
Not a bug, as long as user didn't opt-in to new path length limits (https://msdn.microsoft.com/en-us/librar ... 85%29.aspx). In other case such files shouldn't exist and they are simply erroneous.
RomanM
Post by RomanM »
I have 1 as a value of the LongPathsEnabled registry key under the HKLM\SYSTEM\CurrentControlSet\Control\FileSystem, if I understood correctly, this means that I opted in for the long paths. But I'm still having this problem.
This problem is supposed to be fixed in XnView MP 0.91. Please check and confirm the bug fix here.
