Wrong Default for "Use all formats available"
Locked
When starting XnView, it shows the tips dialog with various tips. One tip says that by default not all formats are available and that the option "Use all formats available" should be changed if needed.
But when starting XnView for the first time this setting is active, already?
Also, in options, category "Write > File types", all formats are checked by default. Shouldn't only the most common ones be checked?
Dreamer
Post by Dreamer »
helmut wrote:1. When starting XnView, it shows the tips dialog with various tips. One tip says that by default not all formats are available and that the option "Use all formats available" should be changed if needed.
2. Also, in options, category "Write > File types", all formats are checked by default. Shouldn't only the most common ones be checked?
1. Right.
2. I agree.
Re: Wrong Default for "Use all formats available"
helmut wrote:When starting XnView, it shows the tips dialog with various tips. One tip says that by default not all formats are available and that the option "Use all formats available" should be changed if needed.
Are you sure, because only most common format are used by default, not all
Dreamer
Post by Dreamer »
Rename xnview.ini file and check those options.
Dreamer wrote:
helmut wrote:...
1. Right.
2. I agree.
Thank you for the backup, Dreamer. Always good to have agreement of a second person. :-)
Locked
