Rotate image in 0.1 or 0.01 degree increment
Moderators: XnTriq, xnview
Locked
Helman
Post by Helman » Fri Sep 30, 2005 1:39 pm
I wish Xnview can Rotate image in 0.1 or 0.01 degree increment, instead of 1 degree as in current version.
Re: Rotate image in 0.1 or 0.01 degree increment
Post by xnview » Fri Sep 30, 2005 1:45 pm
Helman wrote:I wish Xnview can Rotate image in 0.1 or 0.01 degree increment, instead of 1 degree as in current version.
Ok, i'll add it
Post by helmut » Fri Sep 30, 2005 3:28 pm
Ok, i'll add it
Good. There have been other people requesting this, too, see topic "DeSkew or Straighten".
But is 0.01 really needed or are 0.1 steps sufficient?
ckv
Post by ckv » Sat Oct 01, 2005 10:14 am
helmut wrote:But is 0.01 really needed or are 0.1 steps sufficient?
Yes it is. Trust me. Ok to be honest I am not so sure my self, but I would go the 0.01 way. Anyway in experience I can say that rotating pictures with the 1-degree steps is ridiculous so I want to at least test if the 0.01 steps are ridiculous too.
Dreamer
Post by Dreamer » Sun Feb 05, 2006 9:53 pm
Added.
Closed.
Locked
