GIF loop doesn't save with slideshow
clonedone
Post by clonedone »
Hi dev, thank you so much for fixing the loop issue on slideshow. Now the gifs loop correctly and for the correct amount of time. The only issue now, is when I save the SLD file with GIF LOOP checked, it doesn't get saved. Meaning when I load the SLD file again, or run the SLD file on it's own, GIF LOOP is unchecked, so gifs only play once and wait the for the timer before it plays the next part of the slideshow. Is there a fix for this issue? Thanks again for this wonderful program!
I am using version 2.40 on Windows 10
EDIT: GIF LOOP stays checked on the saved SLD file as long as I don't close XNview. But if I close XNview, and load the sld file, GIF LOOP is unchecked again.
Re: GIF loop doesn't save with slideshow
it was fixed in 2.41 version
