XnView MP 0.87 beta 2
**** Please do not post bugs or requests in this topic!
**** In this new test version 0.87 beta 2 various bugs have been fixed. All reported bugs that aren't listed in the changelog below will be fixed in a later release. Please do not re-report a bug which wasn't fixed yet.
XnView 0.87 beta 2 is available for beta testing. You can download XnView MP 0.87 beta 2 here:
Windows x64 ZIP version: http://www.xnview.com/beta/XnViewMP-win-x64-beta2.zip
MacOSX version: http://www.xnview.com/beta/XnViewMP-mac-x64-beta2.tgz
If you have reported one or several bugs listed below, we'd kindly ask you to check with the latest version whether the bug really has been fixed and confirm this with a short note in the specific topic with the bug report.
Thank you for your help!
Changelog 0.87:
1287: [New] Zealous Crop - http://newsgroup.xnview.com/viewtopic.php?t=35860
1286: [New] Film simulation (clut from InstaCam)
1275: [New] Setting for highlight selection - http://newsgroup.xnview.com/viewtopic.php?t=35808
1249: [New] Comment field (embbeded or description) - http://newsgroup.xnview.com/viewtopic.php?t=35281
0845: [New] Delete files or categories in browser - http://newsgroup.xnview.com/viewtopic.php?t=32816
1285: [Bug] Annotation in contact sheet
1284: [Bug] Batch convert: Save and delete original - http://newsgroup.xnview.com/viewtopic.php?t=35670
1283: [Bug] 'Fixed ratio' should be set with image ratio - http://newsgroup.xnview.com/viewtopic.php?t=35848
1282: [Bug] Sort in view mode not always correct - http://newsgroup.xnview.com/viewtopic.php?t=35832
1281: [Bug] Favorites pane sometimes empty - http://newsgroup.xnview.com/viewtopic.php?t=35834
1280: [Bug] PSD thumbnail support - http://newsgroup.xnview.com/viewtopic.php?t=35810
1279: [New] Batch Convert - Start index for #
1278: [Bug] Crash after file(s) are deleted or moved - http://newsgroup.xnview.com/viewtopic.php?t=35462
1277: [Bug] Batch Convert: Save 'Delete' question choice
1276: [Bug] "Update catalog from files" remove categories - http://newsgroup.xnview.com/viewtopic.php?t=35698
1274: [Bug] Copy instead of move in the same share - http://newsgroup.xnview.com/viewtopic.php?t=35504
1273: [Bug] Import category list - http://newsgroup.xnview.com/viewtopic.php?t=35741
1272: [Bug] Custom order doesn't reset header indicator - http://newsgroup.xnview.com/viewtopic.php?t=35296
1271: [Bug] Sidecar: Export Rating/label doesn't export categories - Export categories doesn't export rating/label
1270: [Bug] Update catalog needs 'Import subject' setting - http://newsgroup.xnview.com/viewtopic.php?t=35698
1269: [Bug] Renaming video file in use - http://newsgroup.xnview.com/viewtopic.php?t=35254
1268: [Bug] XnView MP can rename files to too long names - http://newsgroup.xnview.com/viewtopic.php?t=34411
1267: [Bug] Tabbing impossible in dialogs with multi-line fields - http://newsgroup.xnview.com/viewtopic.php?t=35244
1266: [Bug] Compare - shortcut & selection - http://newsgroup.xnview.com/viewtopic.php?t=35592
1265: [Bug] Create "joining images" based on DNG ignoring the embedded preview - http://newsgroup.xnview.com/viewtopic.php?t=35645
1232: [Bug] Fullscreen: "Quit" closes program - http://newsgroup.xnview.com/viewtopic.php?t=30824
1263: [Bug] Batch convert - Canvas resize interface - http://newsgroup.xnview.com/viewtopic.php?t=35793
1264: [Bug] GPS tag missing - http://newsgroup.xnview.com/viewtopic.php?t=35690
1262: [Bug] "Maximum of view tabs" option is ignored sometimes - http://newsgroup.xnview.com/viewtopic.php?t=35247
1261: [Bug] "View » Reset X/Y" does not work - http://newsgroup.xnview.com/viewtopic.php?t=35552
1260: [Bug] Category assignment - http://newsgroup.xnview.com/viewtopic.php?t=35584
1259: [Bug] Crash when pressing <Ctrl> + </> in Browser-Mode with folder selected - http://newsgroup.xnview.com/viewtopic.php?t=35628
1258: [Bug] Moving a folder on itself in Detail View - http://newsgroup.xnview.com/viewtopic.php?t=35370
1257: [Bug] Theme not checked - http://newsgroup.xnview.com/viewtopic.php?t=18636
1256: [Bug] Preview and Browser navigation issues with videos - http://newsgroup.xnview.com/viewtopic.php?t=35222
1255: [Bug] Mac folder numeric sorting - http://newsgroup.xnview.com/viewtopic.php?t=34548
1254: [Bug] Selection ratio in main menu and crop toolbar out of sync - http://newsgroup.xnview.com/viewtopic.php?t=35526
1253: [Bug] Slide show: Same image shown multiple times - http://newsgroup.xnview.com/viewtopic.php?t=35062
1252: [Bug] Drag and drop doesn't work in List view - http://newsgroup.xnview.com/viewtopic.php?t=35297
1251: [Bug] PSB format - http://newsgroup.xnview.com/viewtopic.php?t=34134
1250: [Bug] Restoring layout reverts info pane tab - http://newsgroup.xnview.com/viewtopic.php?t=35088
1248: [Bug] Manual refresh doesn't refresh folder tree - http://newsgroup.xnview.com/viewtopic.php?t=35075
1247: [Bug] Toolbar item "show files in subfolder" doesn't show stat - http://newsgroup.xnview.com/viewtopic.php?t=29652
1246: [Bug] Browser: Menu "Edit > Properties" missing - http://newsgroup.xnview.com/viewtopic.php?t=33970
1079: [Bug] Wrong multi-selection after mouse wheel selection - http://newsgroup.xnview.com/viewtopic.php?t=34719
1245: [Bug] Bug when selecting files with the keyboard - http://newsgroup.xnview.com/viewtopic.php?t=33945
1244: [Bug] UI: Slash in path - http://newsgroup.xnview.com/viewtopic.php?t=34392
1243: [Bug] Resizing problem - http://newsgroup.xnview.com/viewtopic.php?t=31350
1242: [Bug] Copy Image does not work - http://newsgroup.xnview.com/viewtopic.php?t=34652
1241: [Bug] Thumbs+Details: Strange behaviour when Renaming - http://newsgroup.xnview.com/viewtopic.php?t=35225
1240: [Bug] Reset fit when next/previous file - http://newsgroup.xnview.com/viewtopic.php?t=34416
1239: [Bug] Results of scanning aren't added to the browser - http://newsgroup.xnview.com/viewtopic.php?t=34446
1238: [Bug] Add Noise filter does not respect the mask - http://newsgroup.xnview.com/viewtopic.php?t=35061
1237: [Bug] Artefacts when high quality zooming 4-color greyscale - http://newsgroup.xnview.com/viewtopic.php?t=35064
1236: [Bug] Large image thumbnail problem - Thumbnail of large images are dark
1235: [New] Comment encoding - http://newsgroup.xnview.com/viewtopic.php?t=35542
1234: [Bug] Hierarchy not saved in IPTC keywords - http://newsgroup.xnview.com/viewtopic.php?t=35755
1233: [Bug] Darkened screen when closing context menu - http://newsgroup.xnview.com/viewtopic.php?t=35104
1231: [Bug] Keyboard shortcuts "fast image scrolling" missing - http://newsgroup.xnview.com/viewtopic.php?t=33224
1230: [Bug] Details View: Middle Mouse Click Doesn't Open File - http://newsgroup.xnview.com/viewtopic.php?t=33618
1229: [Bug] When the Favourite is non-existent - http://newsgroup.xnview.com/viewtopic.php?t=30769
1228: [Bug] Database search progress not indicated - http://newsgroup.xnview.com/viewtopic.php?t=35095
1227: [Bug] "Shadow" & "Conbright" don't respect selection - http://newsgroup.xnview.com/viewtopic.php?t=35193
1226: [Bug] Video volume is changed when changing mode - http://newsgroup.xnview.com/viewtopic.php?t=35331
1225: [Bug] Status bar not updated with 1st file at beginning - http://newsgroup.xnview.com/viewtopic.php?t=35175
1224: [Bug] Purge 'Most recently used files&dirs' on exit - http://newsgroup.xnview.com/viewtopic.php?t=16966
1223: [Bug] Focus lost after searching - http://newsgroup.xnview.com/viewtopic.php?t=35177
1222: [Bug] Symbolic directory link - http://newsgroup.xnview.com/viewtopic.php?t=34417
1221: [Bug] Volume doesn't always mute when at zero - http://newsgroup.xnview.com/viewtopic.php?t=34888
1220: [Bug] Tree navigation with keyboard issue - http://newsgroup.xnview.com/viewtopic.php?t=35329
1219: [Bug] Image "jumps" when selecting requires scrolling - http://newsgroup.xnview.com/viewtopic.php?t=34969
1218: [Bug] Autoexpand subfolders in folder tree - http://newsgroup.xnview.com/viewtopic.php?t=35293
1217: [Bug] Disable catalog - http://newsgroup.xnview.com/viewtopic.php?t=35521
1216: [Bug] Thumbnail for folder's link - http://newsgroup.xnview.com/viewtopic.php?t=33943
1215: [Bug] .jpg_original files after editing metadata - http://newsgroup.xnview.com/viewtopic.php?t=35404
1214: [Bug] Multi-selection in browser: Wrong state of menu items - http://newsgroup.xnview.com/viewtopic.php?t=35346
1213: [Bug] Wrong thumbnail orientation for raw files - http://newsgroup.xnview.com/viewtopic.php?t=35511
1212: [Bug] Batch renaming, enter key problem - http://newsgroup.xnview.com/viewtopic.php?t=35260
1211: [Bug] HLS-Temperature don't use selection rectangle - http://newsgroup.xnview.com/viewtopic.php?t=35251
1210: [Bug] No Drag&Drop to parent folder - http://newsgroup.xnview.com/viewtopic.php?t=34871
1209: [Bug] Manually set video position ignored - http://newsgroup.xnview.com/viewtopic.php?t=35292
1208: [Bug] Thumbnails+filenames view: Filename truncated - http://newsgroup.xnview.com/viewtopic.php?t=35258
1207: [Bug] View mode doesn't detect file removed - http://newsgroup.xnview.com/viewtopic.php?t=35435
1206: [Bug] Keep Ratio and Preset Sizes Issues - http://newsgroup.xnview.com/viewtopic.php?t=35548
1205: [Bug] No message box "...will lose all existing metadata" - http://newsgroup.xnview.com/viewtopic.php?t=35429
1204: [Bug] Change EXIF orientation field when EXIF doesn't exist - http://newsgroup.xnview.com/viewtopic.php?t=35749
1203: [Bug] Remove file on Linux sometimes doesn't work - http://newsgroup.xnview.com/viewtopic.p ... 8&p=142932
1202: [Bug] Batch convert watermark: when watermark is bigger than image + right position
1199: [Bug] Can't disable 'format color' on Thumbnails+label mode
1200: [Bug] Edit GPS change always the file date - http://newsgroup.xnview.com/viewtopic.php?t=35682
1198: [Bug] Settings in Registry - http://newsgroup.xnview.com/viewtopic.php?t=35603
1196: [Bug] TIF > 2GB & multipage - http://newsgroup.xnview.com/viewtopic.php?t=35056[/quote]
masterjp
Re: XnView MP 0.87 beta 2
Post by masterjp »
Thanks for beta 2! Now I am happy. :)
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill
OS: Windows 10 Pro x64 (latest updates) | XN-View (latest stable version) |XnViewMP (latest stable version) | XnConvert (latest) | Adobe Photoshop Elements 2022 & Elements XXL 9
iMiKE
Post by iMiKE »
Thank you so much for beta2!
