MBM format is wrong!
jumpjack
Post by jumpjack »
I think the MBM format is wrong in XNView: it can't read properly files generated using MBMWhizard, and files generated by XNView can't be read both by MBMWhizard and OPL programs on UIQ platform.
I know two links about MBM format:
http://www.cix.co.uk/~mrudin/psion/bnf.txt
http://www.koeniglich.de/epoc32_fileformats.txt
jumpjack
Post by jumpjack »
BTW, here you can find four MBM samples created by MBMWhizard:
http://jumpjack.altervista.org/bigkeys/testskins.html
jumpjack wrote:BTW, here you can find four MBM samples created by MBMWhizard:
Ok, i'll check
Post by Guest »
Ok, i'll check
Checked?
Ok, i'll check
Checked?
Yes, but now i must see why there is a problem...
