Any way to see video/audio attributes in XnViewMP 0.86?
Moderators: XnTriq, xnview, Dreamer
cadu
Post by cadu » Wed Jun 28, 2017 2:53 pm
The snapshot below is from ACDSee, which provides information about video/audio attributes (e.g. length, frame rate, channels).
XnViewMP 0.86 can read and preview all types of video/audio I tried so far.
However, I could see in XnView attributes just to images, but not to audio/video files. I mean, specific attributes as those listed by ACDSee for audio/video.
Is there any way to see those specific video/audio attributes in XnView?
Thanks for info!
Carlos_Cadu
Re: Any way to see video/audio attributes in XnViewMP 0.86?
Post by xnview » Sat Jul 08, 2017 1:21 pm
ok, it will be good to have
cadu
Post by cadu » Sat Jul 08, 2017 2:26 pm
Thanks for considering it Pierre!
It follows a snapshot with details of video/audio attributes in ACDSee:
Post by xnview » Mon Apr 16, 2018 11:41 am
Audio/Video information will be added in next release
cadu
Post by cadu » Mon Apr 16, 2018 3:00 pm
What a great news. Thanks for implementing that Pierre!
By the way, another functionality that could improve a lot video/audio handling in XnViewMP is to "add autoplay button in the player bar", as described in this thread: viewtopic.php?f=60&t=34513&p=143582#p137096
Post by xnview » Thu Jun 07, 2018 9:45 am
This problem is supposed to be fixed in XnView MP 0.91. Please check and confirm the bug fix here.
cadu
Post by cadu » Wed Jun 20, 2018 12:59 pm
Hi.
I checked Beta 0.91 and I couldn't see anything related to video/audio attributes.
I checked the columns in the browser and the metadata info in "view" settings (https://i.imgur.com/etNmqna.png).
Where are video/audio attributes supposed to be found/accessed?
Thanks!
Post by xnview » Thu Jun 21, 2018 5:07 am
Hi.
Thanks!
it's in the info pane (browser)
cadu
Post by cadu » Tue Jul 03, 2018 1:16 pm
Hi Pierre.
Now I could see the video/audio info!
Since there are very few attributes being showed for video/audio currently, I would suggest more useful information be added in XnView. Would it be possible?
Based on information showed by MediaInfo (https://mediaarea.net/en/MediaInfo), these are my suggestions:
AUDIO:
VIDEO (since audio is included in video files, I also suggest XnView to show audio info when video is selected):
Thanks!!!
Carlos
Post by xnview » Mon Jul 09, 2018 9:55 am
yes i'll add these fields
cadu
Post by cadu » Mon Jul 09, 2018 10:40 am
Thanks a lot Pierre!
cadu
Post by cadu » Thu Jul 19, 2018 8:36 am
Hi Pierre,
Thanks a lot for improving shown attributes in info pane of v0.91 beta 3!!!
The new functionality makes XnView a powerful Digital Asset Management for content creators.
I tested beta 3 and there are two points I would like to comment on/suggest further:
a) For video files, after you expand the video/audio info, when you change files that are diverse on having/having not video+audio, the video/audio info is collapsed automatically. Is it possible to force already expanded video/audio info to keep expanded when navigating these files?
I recorded my screen showing the issue: http://bit.ly/2LoHrW3
b) Since the info pane now provides all important information about video/audio attributes, I would suggest you make the most important info also available in the STATUS bar, same way it already shows metadata for image files. Please, see the images below in which I simulate XnView status bar showing metadata in a similar way that MediaInfo basic view shows. Would it be possible?
Thank you very much!
Carlos
Post by xnview » Fri Jul 20, 2018 11:09 am
ok...
Please make a new post as suggestions
