Change default double-click View for ico files
Moderators: XnTriq, xnview
sibojan
Post by sibojan » Sun Jun 11, 2017 5:48 pm
I recently upgraded win7 to win10. Some issues happened with ico files types.
Double-click jpg files, it shows the View mode.
Double-click ico file, it shows the Browser mode.
How can I change the default view to View mode for all file types?
I use the portable xniew 2.40.
Re: Change default double-click View for ico files
Post by xnview » Thu Jun 15, 2017 8:15 am
please check the registry entries for .ico and .jpg, it seems that there is a problem
servicesp
Post by servicesp » Thu Jul 06, 2017 8:58 am
got regedit and find
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\.txt\UserChoice
- In the right-pane, note down the value data for Progid
-If the UserChoice branch does not exist, navigate to the following branch:
HKEY_CLASSES_ROOT\.txt
In the right-pane, double-click (default) and mention the path to your custom icon
edit that and close.
sibojan
Post by sibojan » Sat Oct 21, 2017 8:32 pm
Problem solved.
"F:\XnView\xnview.exe" "%1"
For .ico file type, the "%1" was missing.
V@no
Post by V@no » Fri Dec 07, 2018 5:42 pm
Just bumping this topic, as this is must be a bug in XnView itself...
On Windows 10 there is no "actions" for .ico files, however adding "%1" after a space to the end of default value in
HKEY_CLASSES_ROOT\Applications\xnview.exe\shell\open\command
fixes the problem
So it should look like this (your path might be different)
"C:\Program Files(x86)\XnView\xnview.exe" "%1"
(note the space between quotes)
