Clean Metadata re-encodes JPEGs?
Moderator & Librarian
XnView v2.40 (and possibly previous versions):
  • Download Karl02's exif-orientation-testimages-v2.rar and extract the archive.
  • Remove the write protection attributes from the extracted files.
  • Select F2_1.jpg in browse mode and go to EditMetadataClean....
  • Deactivate all checkboxes except XMP and hit the OK button.
Expected behavior: File remains untouched (no changes)
Actual behavior: File is re-encoded (conversion from baseline to progressive DCT and from standard to optimized Huffman table) :bug:
JPEGsnoop ([color=green]F2_1.jpg[/color]) wrote:
JPEGsnoop 1.7.5 by Calvin Hass
  http://www.impulseadventure.com/photo/
  Filename: [X:\exif-orientation-testimages-v2\F2_1.jpg]
  Filesize: [9521] Bytes
Start Offset: 0x00000000
*** Marker: SOI (xFFD8) ***
  OFFSET: 0x00000000
*** Marker: APP0 (xFFE0) ***
  OFFSET: 0x00000002
  Length     = 16
  Identifier = [JFIF]
  version    = [1.1]
  density    = 72 x 72 DPI (dots per inch)
  thumbnail  = 0 x 0
*** Marker: APP1 (xFFE1) ***
  OFFSET: 0x00000014
  Length          = 4664
  Identifier      = [Exif]
  Identifier TIFF = 0x[4D4D002A 00000008]
  Endian          = Motorola (big)
  TAG Mark x002A  = 0x002A
  EXIF IFD0 @ Absolute 0x00000026
    Dir Length = 0x000A
    [Orientation                         ] = 1 = Row 0: top, Col 0: left
    [XResolution                         ] = 72/1
    [YResolution                         ] = 72/1
    [ResolutionUnit                      ] = Inch
    [Software                            ] = "GIMP 2.8"
    [DateTime                            ] = "2015:06:09 13:00:03"
    [Artist                              ] = "Karl02"
    [YCbCrPositioning                    ] = Centered
    [Copyright                           ] = "GNU GPL"
    [ExifOffset                          ] = @ 0x00C4
    Offset to Next IFD = 0x0000013A
  EXIF IFD1 @ Absolute 0x00000158
    Dir Length = 0x0008
    [Compression                         ] = JPEG
    [IFD1.0x0112                         ] = 1
    [IFD1.0x0132                         ] = "2015:06:09 13:00:04"
    [JpegIFOffset                        ] = @ +0x01C4 = @ 0x01E2
    [JpegIFByteCount                     ] = 0x[0000106B] / 4203
    Offset to Next IFD = 0x00000000
  EXIF SubIFD @ Absolute 0x000000E2
    Dir Length = 0x0006
    [ExifVersion                         ] = 02.30
    [DateTimeOriginal                    ] = "2015:06:09 13:00:01"
    [DateTimeDigitized                   ] = "2015:06:09 13:00:02"
    [ComponentsConfiguration             ] = [Y Cb Cr .]
    [FlashPixVersion                     ] = 01.00
    [ColorSpace                          ] = sRGB
*** Marker: COM (Comment) (xFFFE) ***
  OFFSET: 0x0000124E
  Comment length = 28
    Comment=Created with GIMP v2.8.14.
*** Marker: DQT (xFFDB) ***
  Define a Quantization Table.
  OFFSET: 0x0000126C
  Table length = 67
  Precision=8 bits
  Destination ID=0 (Luminance)
    DQT, Row #0:   2   1   1   2   2   4   5   6
    DQT, Row #1:   1   1   1   2   3   6   6   6
    DQT, Row #2:   1   1   2   2   4   6   7   6
    DQT, Row #3:   1   2   2   3   5   9   8   6
    DQT, Row #4:   2   2   4   6   7  11  10   8
    DQT, Row #5:   2   4   6   6   8  10  11   9
    DQT, Row #6:   5   6   8   9  10  12  12  10
    DQT, Row #7:   7   9  10  10  11  10  10  10
    Approx quality factor = 95.04 (scaling=9.93 variance=1.25)
  OFFSET: 0x000012B1
  Table length = 67
  Precision=8 bits
  Destination ID=1 (Chrominance)
    DQT, Row #0:   2   2   2   5  10  10  10  10
    DQT, Row #1:   2   2   3   7  10  10  10  10
    DQT, Row #2:   2   3   6  10  10  10  10  10
    DQT, Row #3:   5   7  10  10  10  10  10  10
    DQT, Row #4:  10  10  10  10  10  10  10  10
    DQT, Row #5:  10  10  10  10  10  10  10  10
    DQT, Row #6:  10  10  10  10  10  10  10  10
    DQT, Row #7:  10  10  10  10  10  10  10  10
    Approx quality factor = 94.91 (scaling=10.18 variance=0.26)
*** Marker: SOF2 (Progressive DCT, Huffman) (xFFC2) ***
  OFFSET: 0x000012F6
  Frame header length = 17
  Precision = 8
  Number of Lines = 255
  Samples per Line = 239
  Image Size = 239 x 255
  Raw Image Orientation = Portrait
  Number of Img components = 3
    Component[1]: ID=0x01, Samp Fac=0x22 (Subsamp 1 x 1), Quant Tbl Sel=0x00 (Lum: Y)
    Component[2]: ID=0x02, Samp Fac=0x11 (Subsamp 2 x 2), Quant Tbl Sel=0x01 (Chrom: Cb)
    Component[3]: ID=0x03, Samp Fac=0x11 (Subsamp 2 x 2), Quant Tbl Sel=0x01 (Chrom: Cr)
*** Marker: DHT (Define Huffman Table) (xFFC4) ***
  OFFSET: 0x00001309
  Huffman table length = 28
  Destination ID = 0
  Class = 0 (DC / Lossless Table)
    Codes of length 01 bits (001 total): 00
    Codes of length 02 bits (001 total): 09
    Codes of length 03 bits (001 total): 08
    Codes of length 04 bits (001 total): 07
    Codes of length 05 bits (001 total): 04
    Codes of length 06 bits (001 total): 06
    Codes of length 07 bits (001 total): 03
    Codes of length 08 bits (001 total): 02
    Codes of length 09 bits (001 total): 05
    Codes of length 10 bits (000 total):
    Codes of length 11 bits (000 total):
    Codes of length 12 bits (000 total):
    Codes of length 13 bits (000 total):
    Codes of length 14 bits (000 total):
    Codes of length 15 bits (000 total):
    Codes of length 16 bits (000 total):
    Total number of codes: 009
  OFFSET: 0x00001327
  Destination ID = 1
    Codes of length 02 bits (000 total):
    Codes of length 03 bits (003 total): 05 06 07
    Codes of length 04 bits (001 total): 08
    Codes of length 05 bits (001 total): 09
    Codes of length 06 bits (001 total): 02
    Codes of length 07 bits (001 total): 04
    Codes of length 08 bits (001 total): 03
    Codes of length 09 bits (000 total):
*** Marker: SOS (Start of Scan) (xFFDA) ***
  OFFSET: 0x00001345
  Scan header length = 12
  Number of img components = 3
    Component[1]: selector=0x01, table=0(DC),0(AC)
    Component[2]: selector=0x02, table=1(DC),0(AC)
    Component[3]: selector=0x03, table=1(DC),0(AC)
  Spectral selection = 0 .. 0
  Successive approximation = 0x01
  OFFSET: 0x00001635
  Huffman table length = 39
  Destination ID = 0
  Class = 1 (AC Table)
    Codes of length 01 bits (000 total):
    Codes of length 03 bits (005 total): 00 06 07 20 37
    Codes of length 04 bits (003 total): 05 08 16
    Codes of length 05 bits (004 total): 10 18 30 36
    Codes of length 06 bits (002 total): 04 40
    Codes of length 08 bits (005 total): 01 02 11 17 32
    Total number of codes: 020
  OFFSET: 0x0000165E
  Scan header length = 8
  Number of img components = 1
  Spectral selection = 1 .. 5
  Successive approximation = 0x02
  OFFSET: 0x000018C9
  Huffman table length = 53
  Destination ID = 1
    Codes of length 03 bits (003 total): 01 02 04
    Codes of length 04 bits (001 total): 00
    Codes of length 05 bits (016 total): 05 07 10 15 16 30 34 35 52 53 71 72 91 A1 B2 D1
    Codes of length 06 bits (001 total): 03
    Codes of length 07 bits (003 total): 06 11 12
    Codes of length 08 bits (001 total): 21
    Codes of length 09 bits (009 total): 08 32 41 61 73 81 B1 B3 C1
    Total number of codes: 034
  OFFSET: 0x00001900
    Component[1]: selector=0x03, table=0(DC),1(AC)
  Spectral selection = 1 .. 63
  OFFSET: 0x00001A68
  Huffman table length = 52
  Destination ID = 1
    Codes of length 03 bits (002 total): 01 03
    Codes of length 04 bits (006 total): 00 02 05 06 71 91
    Codes of length 05 bits (010 total): 10 16 17 30 33 34 53 B1 C1 D2
    Codes of length 06 bits (001 total): 04
    Codes of length 07 bits (002 total): 07 11
    Codes of length 08 bits (003 total): 21 41 51
    Codes of length 09 bits (009 total): 12 22 31 36 52 54 72 73 B2
    Total number of codes: 033
  OFFSET: 0x00001A9E
    Component[1]: selector=0x02, table=0(DC),1(AC)
  OFFSET: 0x00001C19
  Huffman table length = 58
  Destination ID = 0
    Codes of length 03 bits (003 total): 02 03 04
    Codes of length 04 bits (004 total): 00 05 20 B3
    Codes of length 05 bits (005 total): 01 36 75 83 D1
    Codes of length 06 bits (009 total): 06 10 34 35 40 76 95 A3 D3
    Codes of length 07 bits (006 total): 11 12 21 31 94 A5
    Codes of length 08 bits (004 total): 13 14 22 30
    Codes of length 09 bits (007 total): 32 41 42 84 A4 B4 D2
    Codes of length 10 bits (001 total): 63
    Total number of codes: 039
  OFFSET: 0x00001C55
  Spectral selection = 6 .. 63
  OFFSET: 0x000020C3
  Huffman table length = 36
  Destination ID = 0
    Codes of length 01 bits (001 total): 01
    Codes of length 03 bits (002 total): 11 21
    Codes of length 04 bits (001 total): 41
    Codes of length 05 bits (001 total): 40
    Codes of length 06 bits (008 total): 00 10 30 31 50 61 71 80
    Codes of length 07 bits (003 total): 51 70 A1
    Codes of length 08 bits (001 total): 81
    Total number of codes: 017
  OFFSET: 0x000020E9
  Successive approximation = 0x21
  OFFSET: 0x000021E9
    Component[2]: selector=0x02, table=0(DC),0(AC)
    Component[3]: selector=0x03, table=0(DC),0(AC)
  Successive approximation = 0x10
  OFFSET: 0x000022AB
  Huffman table length = 35
  Destination ID = 1
    Codes of length 02 bits (001 total): 01
    Codes of length 03 bits (002 total): 00 F0
    Codes of length 04 bits (006 total): 10 30 51 A1 B1 F1
    Codes of length 05 bits (002 total): 11 C1
    Codes of length 06 bits (003 total): 21 31 41
    Codes of length 07 bits (001 total): 40
    Codes of length 08 bits (001 total): 71
    Total number of codes: 016
  OFFSET: 0x000022D0
  OFFSET: 0x00002374
  Huffman table length = 32
  Destination ID = 1
    Codes of length 02 bits (002 total): 01 30
    Codes of length 03 bits (002 total): 11 A1
    Codes of length 05 bits (003 total): 10 21 31
    Codes of length 06 bits (005 total): 00 40 61 C1 F0
    Codes of length 07 bits (000 total):
    Codes of length 08 bits (000 total):
    Total number of codes: 013
  OFFSET: 0x00002396
  OFFSET: 0x000023FD
  Destination ID = 0
    Codes of length 04 bits (000 total):
    Codes of length 05 bits (004 total): 00 40 51 B1
    Codes of length 06 bits (006 total): 10 30 50 80 A1 F1
    Codes of length 07 bits (003 total): 41 61 70
  OFFSET: 0x00002422
*** Marker: EOI (End of Image) (xFFD9) ***
  OFFSET: 0x0000252F
  Filename: [X:\exif-orientation-testimages-v2\F2_1_Clean.jpg]
  Filesize: [11914] Bytes
  OFFSET: 0x00000000
  OFFSET: 0x00000002
  Length     = 16
  Identifier = [JFIF]
  version    = [1.1]
  thumbnail  = 0 x 0
  OFFSET: 0x00000014
  Length          = 4664
  Identifier      = [Exif]
    Dir Length = 0x000A
    Dir Length = 0x0008
    [IFD1.0x0112                         ] = 1
    Dir Length = 0x0006
  OFFSET: 0x0000124E
  Comment length = 28
  OFFSET: 0x0000126C
  Table length = 67
  Precision=8 bits
  OFFSET: 0x000012B1
  Table length = 67
  Precision=8 bits
*** Marker: SOF0 (Baseline DCT) (xFFC0) ***
  OFFSET: 0x000012F6
  Precision = 8
  OFFSET: 0x00001309
  Huffman table length = 31
  Destination ID = 0
    Codes of length 02 bits (001 total): 00
    Codes of length 03 bits (005 total): 01 02 03 04 05
    Codes of length 04 bits (001 total): 06
    Codes of length 05 bits (001 total): 07
    Codes of length 06 bits (001 total): 08
    Codes of length 07 bits (001 total): 09
    Codes of length 08 bits (001 total): 0A
    Codes of length 09 bits (001 total): 0B
    Total number of codes: 012
  OFFSET: 0x0000132A
  Huffman table length = 181
  Destination ID = 0
    Codes of length 02 bits (002 total): 01 02
    Codes of length 03 bits (001 total): 03
    Codes of length 04 bits (003 total): 00 04 11
    Codes of length 05 bits (003 total): 05 12 21
    Codes of length 06 bits (002 total): 31 41
    Codes of length 07 bits (004 total): 06 13 51 61
    Codes of length 08 bits (003 total): 07 22 71
    Codes of length 09 bits (005 total): 14 32 81 91 A1
    Codes of length 10 bits (005 total): 08 23 42 B1 C1
    Codes of length 11 bits (004 total): 15 52 D1 F0
    Codes of length 12 bits (004 total): 24 33 62 72
    Codes of length 15 bits (001 total): 82
    Codes of length 16 bits (125 total): 09 0A 16 17 18 19 1A 25 26 27 28 29 2A 34 35 36
                                         37 38 39 3A 43 44 45 46 47 48 49 4A 53 54 55 56
                                         57 58 59 5A 63 64 65 66 67 68 69 6A 73 74 75 76
                                         77 78 79 7A 83 84 85 86 87 88 89 8A 92 93 94 95
                                         96 97 98 99 9A A2 A3 A4 A5 A6 A7 A8 A9 AA B2 B3
                                         B4 B5 B6 B7 B8 B9 BA C2 C3 C4 C5 C6 C7 C8 C9 CA
                                         D2 D3 D4 D5 D6 D7 D8 D9 DA E1 E2 E3 E4 E5 E6 E7
                                         E8 E9 EA F1 F2 F3 F4 F5 F6 F7 F8 F9 FA
    Total number of codes: 162
  OFFSET: 0x000013E1
  Destination ID = 1
    Codes of length 02 bits (003 total): 00 01 02
    Codes of length 04 bits (001 total): 04
    Codes of length 05 bits (001 total): 05
    Codes of length 07 bits (001 total): 07
    Codes of length 08 bits (001 total): 08
    Codes of length 09 bits (001 total): 09
    Codes of length 10 bits (001 total): 0A
    Codes of length 11 bits (001 total): 0B
  OFFSET: 0x00001402
  Destination ID = 1
    Codes of length 02 bits (002 total): 00 01
    Codes of length 03 bits (001 total): 02
    Codes of length 04 bits (002 total): 03 11
    Codes of length 05 bits (004 total): 04 05 21 31
    Codes of length 06 bits (004 total): 06 12 41 51
    Codes of length 07 bits (003 total): 07 61 71
    Codes of length 08 bits (004 total): 13 22 32 81
    Codes of length 09 bits (007 total): 08 14 42 91 A1 B1 C1
    Codes of length 10 bits (005 total): 09 23 33 52 F0
    Codes of length 11 bits (004 total): 15 62 72 D1
    Codes of length 12 bits (004 total): 0A 16 24 34
    Codes of length 14 bits (001 total): E1
    Codes of length 15 bits (002 total): 25 F1
    Codes of length 16 bits (119 total): 17 18 19 1A 26 27 28 29 2A 35 36 37 38 39 3A 43
                                         44 45 46 47 48 49 4A 53 54 55 56 57 58 59 5A 63
                                         64 65 66 67 68 69 6A 73 74 75 76 77 78 79 7A 82
                                         83 84 85 86 87 88 89 8A 92 93 94 95 96 97 98 99
                                         9A A2 A3 A4 A5 A6 A7 A8 A9 AA B2 B3 B4 B5 B6 B7
                                         B8 B9 BA C2 C3 C4 C5 C6 C7 C8 C9 CA D2 D3 D4 D5
                                         D6 D7 D8 D9 DA E2 E3 E4 E5 E6 E7 E8 E9 EA F2 F3
  OFFSET: 0x000014B9
    Component[2]: selector=0x02, table=1(DC),1(AC)
    Component[3]: selector=0x03, table=1(DC),1(AC)
  Spectral selection = 0 .. 63
  Successive approximation = 0x00
  OFFSET: 0x00002E88
Re: Clean Metadata re-encodes JPEGs
same thing i think for XnViewMP?
xnview wrote:same thing i think for XnViewMP?
Right, same behavior in both editions.
Mugros
Re: Clean Metadata re-encodes JPEGs?
Post by Mugros »
I face the same issue 6 years later. I want to clean the XMP data but XnViewMP always encodes the image again.
When I clean manually I have to save and then it is encoded again.
When I use batch convert and select "same as original" it also encodes them again.
Mugros wrote: Sat Jul 22, 2023 6:28 pm I face the same issue 6 years later. I want to clean the XMP data but XnViewMP always encodes the image again.
you are not in the good forum
