0.86 Linux - Can not move files by drag & drop, only copy
XnViewOnLinux
Post by XnViewOnLinux »
In the software I used previously, you can drag and drop to move on the same drive or copy to another drive. But if you want to move to another drive then you simply press the CTRL or SHIFT key and the procedure changes to from copy to move. I need to move many files and I have no way to move by drag and drop.
Re: 0.86 Linux - Can not move files by drag & drop, only copy
do you have tried by pressing SHIFT or CONTROL key?
