error: not a picture
Moderators: XnTriq, xnview
mohamed 2
Post by mohamed 2 » Mon May 15, 2017 9:04 pm
I have macOS Sierra (10.12.4) with Xnconvert (version 1.74 x64).
When I add pdf file and want to have the output as JPG, I get the error: not a picture.
Is there any idea?
Thanks in advance
Mohamed
Re: error: not a picture
Post by cday » Mon May 15, 2017 10:02 pm
mohamed 2 wrote:I have macOS Sierra (10.12.4) with Xnconvert (version 1.74 x64).
On the Output tab in Load format settings... on the PS/PDF tab, there is an option Ignore read errors, could you try selecting that setting...
If you haven't already done so, you need to install Ghostscript, 32-bit or 64-bit according to the XnConvert version you are using.
If you still have a problem opening the file, I have the impression that for some unexplained reason XnView software doesn't open some PDF files that other software can open... :?: :?
mohamed 2
Post by mohamed 2 » Tue May 16, 2017 2:51 am
Thanks cday, I did as you said and still the error. Do you know how to install Ghostscript on mac.
Thank you,
Mohamed
Moderator & Librarian
Post by XnTriq » Tue May 16, 2017 3:45 am
mohamed 2 wrote:Do you know how to install Ghostscript on mac.
:arrow: xx.pdf 0x0x0 : not a picture :-)
mohamed 2
Post by mohamed 2 » Tue May 16, 2017 5:53 pm
Many many many thanks XnTriq. Yes, now it works. I followed this link in your original link (xx.pdf 0x0x0 : not a picture):
Richard Koch
Ghostscript install package for macOS
and downloaded Ghostscript 9.21 and it is excellent now. No errors.
Just to summarizes, for those on mac, install ghostscript to avoid error: not a picture.
Best regards XnTriq,
Mohamed
Post by XnTriq » Tue May 16, 2017 8:15 pm
mohamed 2 wrote:Just to summarizes, for those on mac, install ghostscript to avoid error: not a picture.
Thanks for reporting back, Mohamed. Welcome to the forum!
