Companion File Handing in MP?
Older bugs which are supposed to be fixed in 0.84. *** Please try to reproduce your bug and confirm the bug fix. ***
Moderator: Dreamer
Re: Companion File Handing in MP?
Post by xnview » Thu Jul 19, 2018 12:56 pm
andrewj wrote:
Thu Jul 19, 2018 12:26 pm
Hi Pierre,
Definitely no context menu for me. I have tried both left and right clicking in both columns...
I show companion files - I run with all three boxes checked.
Andrew
beta 3?
andrewj
Post by andrewj » Thu Jul 19, 2018 1:17 pm
That may be the problem. I followed the link in your post to the beta page viewtopic.php?f=108&t=37553, but that seems to be for Beta 1. How do I find the latest beta?
Post by xnview » Thu Jul 19, 2018 2:04 pm
andrewj
Post by andrewj » Thu Jul 19, 2018 2:55 pm
Hi Pierre,
Thanks. I have installed beta 4. That solves the context menu issue, but I still can't drag/drop to copy/move, but if I do a cut and paste it works OK.
Is there anything else I can check?
Andrew
Post by xnview » Thu Jul 19, 2018 3:39 pm
you drag&drop a cr2 file?
andrewj
Post by andrewj » Thu Jul 19, 2018 5:04 pm
No. I tried renaming a .ARW to .CR2, but it didn't work. I also tried making sure that all files have lowercase extensions, but that doesn't make any difference.
m.Th.
Post by m.Th. » Fri Jul 20, 2018 10:32 am
I confirm that drag & drop doesn't support sidecars/companions. See here for my report which depicts TWO bugs: (drag & drop and desyncing for the names)
viewtopic.php?f=110&t=29532&start=15#p151059
...also it has some problems with refresh:
viewtopic.php?f=110&t=29532&start=15#p151056
m. Th.
The Ascetic Experience - The best photos and texts from Holy Mountain (Athos)
- Dark Themed XnViewMP 0.90 64bit & XnView 2.00 x64 on Win7 x64 -
Post by xnview » Fri Jul 20, 2018 11:31 am
do you use 'show companions'? Do you drag&drop files from thumbnail view to a subfolder in thumbnails view?
andrewj
Post by andrewj » Fri Jul 20, 2018 11:54 am
Hi Pierre,
I do use "show companions". If I turn it off, the .xmp files are hidden, but not the .JPG files. I don't know if it's significant, but I've noticed that the .RW2 and .JPG are uppercase, but .xmp is lowercase. It shouldn't make a difference under Windows, but I don't know about your code.
I usually drag and drop the raw file from a thumbnail view to another folder in the explorer. That works OK in XnView.
Thanks
Andrew
robo
Post by robo » Mon Sep 03, 2018 9:57 pm
If I understand Andrew's issue, I think I have the same behaviour on my side using beta4:
With .cr2 set as master and .jpg as companion, it still shows both in the browser.
However, if the .jpg is the master with .cr2 as companion, I only see the .jpg.
I can see the logic where you want to show the lightest file instead of the raw but I'm not sure if it's intended to work only in one direction or if it's simply a bug.
Anyways, I could live with that if I could set the "open with" programs to open one of the companion files with a specific extension instead of the master:
I would browse the jpg catalog in XnViewMP for a picture I want to edit in my raw processing software and by clicking edit with said software, it would open the associated raw file instead of the jpg.
The other thing that would be nice to have: to see the extensions of the associated companion files next to the name of the file (or anywhere near the thumbnail) in the browser to quickly see what is available. Maybe even adding this as a new variable to allow us to add this when customizing the info in the tooltips,etc.
Thanks
Arthur
