I often convert pictures in jpg from tga using the conversion button.
If the tga has a alpha map when converting to jpg part of the pictures disappear (because the conversion always use the alpha map if it exists).
Among the option of the conversion I cannot find "discard alpha maps". I want an option that automatically remove alphas when converting pictures.
Thanks.
Removing Alphas from image.
- Moderator & Librarian
Re: Removing Alphas from image.
Hi jeeg
There are several ways to discard the alpha mask in XnView:
- Tools → Options... → General → Operations → Ignore alpha channel
- Tools → Options... → Read/Write → General → Remove alpha channel if output format doen't support it
- View → Use alpha channel
I forgot to say "Thank you for your reply!"
jeeg wrote:I forgot to say "Thank you for your reply!"
