Change order of elements in status bar on browser mode
JMM72
Post by JMM72 »
On browser mode, the status bar shows several data about the currently selected image(s). One problem is that the space reserved for the filename is very narrow, and despite most of the status bar being blank, the filename is cropped.
This could be easily solved if the filename would be moved to the last place and let it have all the remaining status bar space, which is for the most part blank. I'd also say it would be a pretty easy change.
m.Th.
Re: Change order of elements in status bar on browser mode
Post by m.Th. »
Fixed in 0.85
m. Th.
JMM72
Post by JMM72 »
This is still unchanged as of 0.89.
m.Th.
Post by m.Th. »
It seems now that the space is large enough. TBH I would prefer to have the file at the end but now it seems that the file name is in the same place but the space is larger. I work with 0.90b1 . How it is for you?
m. Th.
SonicTHI
Post by SonicTHI »
Still unchanged as of 0.92.
Currently if the file name is longer than 27 chars it gets truncated.
Can we at least have an option to always show the full filename in the status bar?
you can change maxCharsFilename in [Viewer] section of xnview.ini
