XnView and Category
Moderators: XnTriq, xnview
a-zwo
XnView and Category
Post by a-zwo » Sun Apr 16, 2017 6:54 pm
Hi, I would like to put more then one Photo in one step into a category (i.e. a full directory with 1.000 photos selected by <ctrl>+a), but I found no way to do this. What can I do? (XnView V.2.39-privat)
Thanks for any ideas ...
__________________________________________________
Best regards ... a-zwo
Re: XnView and Category
Post by xnview » Mon Apr 17, 2017 8:01 am
select the files, and drag&drop them on the category
a-zwo
Post by a-zwo » Mon Apr 17, 2017 1:13 pm
First: Thanks for information - the workaround works perfect.
There remains the question, what the function from "view / set categories ..." (Ansicht / Kategorien zuordnen ...) should do?
Post by xnview » Mon Apr 17, 2017 1:25 pm
a-zwo wrote: There remains the question, what the function from "view / set categories ..." (Ansicht / Kategorien zuordnen ...) should do?
the same
a-zwo
Post by a-zwo » Mon Apr 17, 2017 4:11 pm
Thanks for the fast answer, I had hope so.
The function doesn't work (nothing) - now I have re-installed XnView and its works ... what ever.
Ok and thanks for the good help.
