0.85: *.jpg_original files after editing metadata
Older bugs which are supposed to be fixed in 0.84. *** Please try to reproduce your bug and confirm the bug fix. ***
Moderator: Dreamer
monitor
Post by monitor » Tue Apr 11, 2017 6:22 pm
After working with some images - editing and inspecting metadata - mostly with XnViewMP, I find several files with the extension jpg_original in my directories.
I understand that these might be produced by ExifTool; I did inspect some files by some Exiftool derivatives or GUI front ends, but I don't recall editing or changing any data with those.
Does XnViewMP use Exiftool in any way for editing or changing the images.
TIA.
PS: I did search the fori=um, but the search engine always ignores the jpg_ prefix :-(
m.Th.
Re: *.jpg_original
Post by m.Th. » Wed Apr 12, 2017 1:19 pm
ExifTool is definitely used in displaying EXIF data in certain cases (there is a dedicated tab for it) - however these files appear only when EXIF is modified (?)
m. Th.
The Ascetic Experience - The best photos and texts from Holy Mountain (Athos)
- Dark Themed XnViewMP 0.90 64bit & XnView 2.00 x64 on Win7 x64 -
Re: 0.85: *.jpg_original files after editing metadata
Post by helmut » Tue Apr 18, 2017 6:53 pm
After browsing search results for "jpg_original" and the above descriptions it's pretty sure that these files are created by Exiftool.
@Pierre: In which detailed scenario are these file created? Are these files of some use for the XnView user? Is there a way to surpress these files?
Post by xnview » Wed Apr 19, 2017 7:07 am
these files are created by ExifTool as a backup
Post by helmut » Wed Apr 19, 2017 7:54 am
xnview wrote:these files are created by ExifTool as a backup
O.k., that confirms the assumption.
From the user perspective there is XnView MP, only, and it looks as if XnView MP creates these files. I much doubt that these files are wanted by users. Is there a way to surpress these backup files?
Post by xnview » Wed Apr 19, 2017 8:35 am
yes, but only if the setting for backup is not enabled
Post by helmut » Wed Apr 19, 2017 11:43 am
How can the user change the setting for backup? In XnView MP? Or in ExifTool? As written before from the user perspective there is XnView MP, only. Could you add a setting in XnView MP that allows for changing the setting for backup?
Post by xnview » Wed Apr 19, 2017 11:49 am
settings>General>File operations>lossless transformations (but currently doesn't if exiftool is used)
Post by helmut » Wed Apr 19, 2017 12:26 pm
xnview wrote:settings>General>File operations>lossless transformations (but currently doesn't if exiftool is used)
Many posts but little info. :? The setting you mention is for JPEG lossless transformation. But is there a setting that allows a user to enable/disable the creation of files by the EXIF tool? Could you add such a setting in XnView MP?
Post by xnview » Wed Apr 19, 2017 12:43 pm
sorry not this one settings>File operations>Make backup
As i said currently the setting doesn't work with Exitool, need to be fixed
Post by helmut » Fri May 12, 2017 12:57 pm
xnview wrote:sorry not this one settings>File operations>Make backup
O.k. I guess two (or more) settings would be good:
1. "Make backup when applying lossless JPEG transformations"
2. "Make backup when writing IPTC/EXIF data (EXIFTool)"
:arrow: Reproduced
Post by xnview » Sat Jun 17, 2017 6:27 pm
O.k., thank you, I can also reproduce the problem. Issue 1215 is fixed in next version.
Post by xnview » Sat Jul 08, 2017 12:48 pm
This problem is supposed to be fixed in XnView MP 0.87. Please check and confirm the bug fix here.
