XnConvert 1.74
XnConvert 1.74
XnConvert MP (XnView batch convert as multi-platform standalone program) is available.
You can download XnConvert here
Windows x32 Setup Windows x64 Setup
Windows x32 ZIP Windows x64 ZIP
MacOSX x64 TGZ
Linux x32 TGZ Linux x64 TGZ
Linux x32 DEB Linux x64 DEB
Linux x32 RPM Linux x64 RPM
For ArchLinux/Gentoo/Manjaro distribution, please replace the executable with
Linux 32bits Linux 64bits
http://itunes.apple.com/app/xnconvert/id436203431?mt=12
Changelog:
* Many bugs fixed
You can use
XnConvert file1 file3 file3
or
XnConvert @filelist
David999
Re: XnConvert 1.74
Post by David999 »
Why won't it open on my mac? DLed it and tried to open it but: "“XnConvert” can’t be opened. You should move it to the Trash." Any help would be appreciated.
Re: XnConvert 1.74
David999 wrote:Why won't it open on my mac? DLed it and tried to open it but: "“XnConvert” can’t be opened. You should move it to the Trash." Any help would be appreciated.
yes, i'll update soon a version
David999
Re: XnConvert 1.74
Post by David999 »
Thanks much! :D
FCP
Re: XnConvert 1.74
Post by FCP »
I am still getting this error. Is their a new version that solves this problem?
Macsico
Re: XnConvert 1.74
Post by Macsico »
Same problem here - program cannot be started and would like to go to Trash. Version 1.73 just worked fine.
Maybe it is related to the OS X version? Currently OS X 10.9.5 (13F1911) is running here - an old one for various reasons.
Regards from Berlin
