0.85b4: PDF files (and others?) abort Fullscreen
Moderators: XnTriq, xnview, Dreamer
Re: 0.85b4: PDF files (and others?) abort Fullscreen
Post by helmut » Mon Apr 03, 2017 1:33 pm
xnview wrote:
helmut wrote:For now, same behaviour as 0.84 is o.k.. But in mid-term the grey "ghost" images should be avoided. Either by skipping the non-image files or non-readable files or by having some graphic that is displayed and clearly indicates what the situation is.
i agree, need to search the next good image file like XnView Classic
Yes. Readability of PDF files and some image files depend on the plug-ins and add-ons available which could/should be determined at startup of XnView. Non-supported formats should be just skipped. If there's really an unexpected error reading a specific file, then a message box and/or special graphic could be displayed.
arspr
Post by arspr » Thu Apr 06, 2017 8:46 pm
0.85 has changed the behaviour... but it's not solved.
If you don't have ghostcript or anything like that, when you reach a pdf file Fullscreen shows a blank screen. It doesn't abort Fullscreen but it's distracting.
I think pdfs should be completely jumped when not supported.
ckit
Post by ckit » Sat Jul 08, 2017 1:59 am
I cannot reproduce this bug at all with XnViewMP x64 0.86 with Ghostscript 9.21 (x86 and x64 installed)
1 png image, 1 png image, 1 pdf, 1 png image
Win10 Pro x64 RS4 1803, Malwarebytes Premium, Process Lasso Pro
XnView Classic and PhotoFiltre Studio X
arspr
Post by arspr » Thu Jul 13, 2017 2:15 pm
ckit wrote:I cannot reproduce this bug at all with XnViewMP x64 0.86 with Ghostscript 9.21 (x86 and x64 installed)
Sure, the bug only happens if Ghostscript is not installed...
Re-read my former post.
arspr
Post by arspr » Wed Aug 09, 2017 6:03 pm
I've noticed a behaviour change in 0.87 beta 3, (I don't know if it was previously present): XnView displays a warning message about Ghostscript not being installed when you Esc from a not supported pdf file.
Nevertheless, I do really think this is a sub-optimal solution. You still get the fullscreen blank screen which is fully distracting while viewing your mixed images and files. IMO, if XnView does not support pdfs, (or whichever other files because of whichever reasons), those files should be completely jumped over (as XnView does actually avoid exes, dlls or other similar files).
Post by xnview » Tue Apr 17, 2018 2:32 pm
Post by xnview » Thu Jun 07, 2018 9:44 am
This problem is supposed to be fixed in XnView MP 0.91. Please check and confirm the bug fix here.
arspr
Post by arspr » Tue Aug 07, 2018 3:31 pm
0.91b4 without ghostcript or anything else.
Fixed!!! In full screen only images are shown. Pdfs are jumped.
