0.85b2 MacOS: Preferences and About menu isn't available
iMiKE
Post by iMiKE »
XnView: MP 0.85b2 - x64
OS: macOS Sierra 10.12.4 /64bit
Preferences and About from XnView menu isn't available when you're back to Thumbnails+Filenames view from fullscreen view.
Снимок экрана 2017-03-31 в 23.36.19.png (20.04 KiB) Viewed 2106 times
Effect: Nobody can check About window, nobody can open Preferences.
  1. Launch XnView 0.85b2;
  2. Browse photos on Thumbnails+Filenames view on any drive;
  3. Doubleclick photo to view it fullscreen;
  4. View other photos in fc view;
  5. Press ESC to return to Thumbnails+Filenames view;
  6. Click on XnView in statusbar for opening menu;
  7. About and Preferences are greyed.
Actual behaviour (bug): About and Preferences should be available. Once you view photos in fullscreen view and return to thumbnails, About and Preferences stays inactive. Only program restart helps. :bug:
Expected behaviour: About and Preferences should be always available
Re: 0.85b2: MacOS: Preferences and About menu isn't availabl
Thank you for reporting the problem, iMiKE. I'm not familiar with MacOS: Are the settings of XnView not available or special preferences of MacOS? If it's the XnView settings that would be a serious bug which could be considered as show stopper.
iMiKE
Post by iMiKE »
helmut wrote:Thank you for reporting the problem, iMiKE. I'm not familiar with MacOS: Are the settings of XnView not available or special preferences of MacOS? If it's the XnView settings that would be a serious bug which could be considered as show stopper.
As you can see on Screenshot, About and Preferences are grayed. This is About XnView and Preferences of XnView.
You can't open XnView preferences once you back from fullscreen view.
Re: 0.85b2 MacOS: Preferences and About menu isn't available
@Pierre: This sounds serious. Could you please check?
grgr
Post by grgr »
I can confirm the issue.
(You can still access preferences from the toolbar or after moving to another tab.)
helmut wrote:@Pierre: This sounds serious. Could you please check?
it seems that this is a bug with lastest Qt :(
iMiKE
Post by iMiKE »
Or Lazarus, isn't it?
sd_snatcher
Post by sd_snatcher »
I confirm that the preferences and quit menu items are disabled in my machine too. Tested on Mac OS-X 10.10.5.
As with the other users, the preferences can still be accesses via the icon on the toolbar. The CMD+, (preferences) and CMD+Q (quit), shortcuts work fine too.
iMiKE
Post by iMiKE »
Seems like this big is fixed in beta5.
Thank you very much!
iMiKE
Post by iMiKE »
Just encountered this bug again in 0.86 for MacOSX.
Again, after many work - copyingmoving files, return from fullscreen view to Filelist+Thumbnails About XNView and references menu items is greyed - inaccessible.
iMiKE wrote:Just encountered this bug again in 0.86 for MacOSX.
really i don't have changed something on this side... All menu are greyed?
iMiKE
Post by iMiKE »
xnview wrote: really i don't have changed something on this side... All menu are greyed?
Nope, only About and Preferences.
I can't reproduce this bug again after several attempts.
