Move Between Tabs
ehathgepiurhe
Move Between Tabs
Post by ehathgepiurhe »
In certain circumstances, you can make the little left and right arrows that appear in the XnView window when you have more images open than can be displayed at once in the XnView window not appear. I noticed on my PC that if I open XnView maximised (running at 1280x1024), and then open up say 10 or more images, each one will be displayed in its own tab. Ok so far. However, the little arrows that allow you to display the tabs that are off the screen do not appear. To get them to show up, I have to 'unmaximise' XnView, and then they appear. I can then maximise it again and they stay this time.
CM
Re: Move Between Tabs
ehathgepiurhe wrote:Hi,
Yes, currently a known bug
ehathgepiurhe
Ah, thanks for that.
CM
