0.84: Custom Format colour cannot be removed
Bugs that are confirmed but cannot be fixed for some reasons.
Moderators: XnTriq, xnview, Dreamer
XnView: MP 0.84 - 64 bit
OS: Windows 10 - 64bit
After adding a custom format colour for AVI video files this entry custom format colour can no longer be removed.
Effect: Functionality doesn't work as expected
To reproduce: (steps are copied in parts from XnTriq's description, see http://newsgroup.xnview.com/viewtopic.php?t=33613)
  1. Go to Tools » Settings... » File list » Format colors.
  2. Activate Use color based on file format.
  3. Type avi in the left text box.
  4. Click the Add button.
  5. Select avi in the list.
  6. Choose your preferred colors by clicking the buttons on the right of the dialog.
  7. Confirm with OK.
  8. Point the browser to a folder which contains AVI videos.
--> Format colour is displayed. (correct)
  1. Exit XnView (your settings are saved on exit)
  2. Start XnView
  3. Go to Tools » Settings... » File list » Format colors, again
  4. In the list of formats select "AVI" and select "Remove" button.
  5. Confirm settings with "OK" button
  6. Exit XnView (your settings are saved on exit)
  7. Start XnView
Actual behaviour (bug): Format colour is still displayed. In the settings for format colours the custom entry "AVI" is still listed. :bug:
Expected behaviour: Custom format colour is no longer displayed. In the settings for format colours the custom entry "AVI" is no longer listed.
Re: 0.84: Custom Format colour cannot be removed
i think that format color setting must have a new UI
xnview wrote:i think that format color setting must have a new UI
I agree. See my suggestions in topic 0.83: Format colors isn't working for custom file extensions
