1366x768 in Resize option
Irving
Post by Irving »
Please add it, or at least make it where you can add it in the .ini file.
1366x768 is used in many laptops.
Thanks,
Irving
Windows 10
XnView 2.39
Irving
Re: 1366x768 in Resize option
Post by Irving »
I'd like to bump this. Would still like to see it implemented.
WinnieW
Post by WinnieW »
I can see a customizable setting – as selectable preset – as an alternative, because there are a lot of mobile devices with non-standard screen resolutions around nowadays. (e.g. smartphones and convertible PC).
ok, i'll add it
Irving
Post by Irving »
WinnieW wrote: Sun Sep 09, 2018 9:20 pm I can see a customizable setting – as selectable preset – as an alternative, because there are a lot of mobile devices with non-standard screen resolutions around nowadays. (e.g. smartphones and convertible PC).
The idea of a preset with your own parameters would be just fine with me also.
Irving
Post by Irving »
xnview wrote: Mon Sep 10, 2018 8:03 amok, i'll add it
Thank you!
As WinnieW mentioned, perhaps creating at least one individually controlled preset would be better, instead of your having to keep adding specific resolutions down the road? That way each user has his/her own preset size within easy reach.
Apologies for not responding to you sooner.
Irving
Post by Irving »
Yes! You have added it in 2.47
Thank you!
Irving
Post by Irving »
XnShell 4.0.3 doesn't convert to 1366x768 despite the input. It only resizes to 1024x768.
Irving wrote: Sat Jun 15, 2019 1:14 am XnShell 4.0.3 doesn't convert to 1366x768 despite the input. It only resizes to 1024x768.
when you use 'Convert into' dialog?
Irving
Post by Irving »
xnview wrote: Wed Jun 19, 2019 2:49 pm
Sorry for the late reply.
It's when you click on "Convert..." which goes to a format type and resize dialog.
I'm using Winduhs 10 1903, updated from 1803 just 2 days ago, for what it's worth.
Thanks for your time.
Irving wrote: Thu Jun 20, 2019 5:47 am
and which is the resolution of original picture?
Irving
Post by Irving »
Clipboard01 for XnView.png (5.32 KiB) Viewed 6895 times
I've forgotten which image I was trying to resize. :?
But there's a bug easily reproduced in both my Winduhs 10 (1903) machines:
Take a large image, for example, that's 16:9 such as 1920x1080 and you want to resize it to 1366x768, so you type the sizes in to convert. Maybe you have fat fingers and accidentally type 1365 in the Width box and click the up button to get it to 1366.
The picture will resize to a 1x1 pixel. :shock:
It doesn't do that if you click on the up/down Height buttons, only the Width buttons. Note that you'll also see a comma added, such as 1,366 etc.
It would be nice if you could add at least one "add your own preset size" to this as well as the main XnView program.
Again, thanks for responding.
EDIT: after some experimenting the Resize works correctly if you drop the width to 999 or below. Everything will resize normally with the correct ratio. When you go to 1000 wide or more the comma and problem returns.
Irving wrote: Sun Jun 23, 2019 8:39 pm EDIT: after some experimenting the Resize works correctly if you drop the width to 999 or below. Everything will resize normally with the correct ratio. When you go to 1000 wide or more the comma and problem returns.
Ok, right, i'll fix it
Irving
Post by Irving »
Thanks again.
