"Not enough memory" error with JPEG file
Voronoff
Post by Voronoff »
Tried to view JPEG image with XnView 2.39 but got an error "Not enough memory"
Here is an image https://yadi.sk/d/WLgnt3y63G7mFE
or download Original image form here: http://lgefrontend.qbank.se/media/5003
Re: "Not enough memory" error with JPEG file
you need to use XnView MP 64bits to be able to open this file
xnview wrote:you need to use XnView MP 64bits to be able to open this file
I tried that but it doesn't open in MP either...
And despite it's very large pixel dimensions of 20800 x 20800 x24, the file does open in the 32-bit version of another popular freeware viewer... :?:
Edit: Pixel dimensions and bit depth corrected.
Voronoff
Post by Voronoff »
I prefer XnView Classic. Is it possible to implement the support of such JPEGs in it?
Voronoff
Post by Voronoff »
Updated to XnView 2.40, still no support for large JPG files :(.
Voronoff wrote:Updated to XnView 2.40, still no support for large JPG files :(.
it will be fixed in next version... (64bits OS)
Voronoff
Post by Voronoff »
Many thanks for making a fix in 2.41!
denial
Post by denial »
Same error while trying to open this JPG
https://techbox.dennikn.sk/wp-content/u ... resize.jpg
XnView Classic 2.49.3 32bit @ Windows 10 2004 64bit
denial wrote: Fri Oct 02, 2020 11:36 pm Same error while trying to open this JPG
this file needs 2.5Gb of memory
There is a limit to the memory that XnView Classic as a 32-bit program can address, you need to use a 64-bit software such as XnView MP...
denial
Post by denial »
yeah, it works with
XnView MP Windows
Version 0.97.0 64bits (Sep 23 2020)
